DIY boost leak tester?
Old Sep 16, 2008 | 03:38 PM
integrosse's Avatar
Default DIY boost leak tester?
I've got my car chipped by Unitronic last week and I have noticed that the turbo is only pushing 7-8 psi instead of 18. No cell so I don't really suspect the N75 to be faulty. I want to build a boost leak tester but I found 3 different ways to do it:
http://audizine.com/forum/showthread.php?t=104080
http://forums.audiworld.com/a4/msgs/1659806.phtml
http://a4mods.com/index.php?page=web...boostleak.html
Which one is the proper way? One is only connecting the tester on the TIP, another one is doing the same but is disconnecting the PCV and the other one is also disconnecting the tubing that connect on the intake manifold.
Old Sep 16, 2008 | 08:17 PM
ghost6303's Avatar
sounds like your back in your stock program, you would notice a leak that cuts your boost in half without a leak tester.
any of those methods can work, just start with one, i use the tennis ball method just because i had a tennis ball handy. hook it up, put some air in there and see where you hear it leaking. plug up the leak and repeat, until theres no more leaks. the air will still get past some of the PCV system btw, it will never be completely sealed. just make sure no intake pipe connections and vac lines leak, ignore the rest.
Swan843
Feb 17, 2014 12:36 PM
flynnr
Mar 2, 2010 07:24 AM
flynnr
Feb 15, 2010 12:22 PM
onepoint8tee
Jun 27, 2007 04:38 PM
tooxtreme8813
Aug 24, 2006 03:32 AM
