DIY replace rear differential?
It's looking like I need to switch out the rear differential on my 98.5 2.8 tiptronic.
Is there a DIY writeup for replacing the whole unit? I can only find fluid change writeups. General Questions: + How much does the diff weigh? I'm hoping to do this job solo, with a transmission jack. I'm guessing 80 lbs. + Where do I find the diff code and where can I figure out compatibility. i.e., will any B5 differential work or do I need one with the same code. + To get at the prop shaft bolts, do I need to unbolt the exhaust like you do to access the front differential/output shaft bolts, or is there a way to remove the heat shield and access the bolts with the exhaust in place. |
Originally Posted by redmond1501
(Post 1444985)
(Post 1444985)
May I ask why you are removing the differential? Did it fail on you? Stripped the plug thread?
The clutch packs in my differential are shot.
The less I have to do underneath a car on jackstands, the better, and I'm doing this project solo, so I'm hoping I don't have to drop the exhaust too. Plus, the exhaust is original with the exception of the flex pipes -- 170k miles on it. I found a used differential locally. It's from a 99 manual trans 2.8 car. Anyone know if this is the same differential used in a 98.5 tiptronic 2.8? |
Scratch everything I said. I thought you were talking about the rear diff.
Correct, rear diff. Something in the rear diff is totally shot. Maybe clutch packs is wrong terminology, but the unit is toast.
Yea, there are no clutch packs. Usually a bad pumpkin shows up when you turn the wheel in a parking lot and hear/feel the back wheels fighting each other....because they are.
I think the exhaust is one of those things that saves you 15 minutes and costs you an hour. And if you have the original flexes at 170,000 miles, they're going to go soon any way. You only have to take the exhuast apart to the sleaves in the middle of the car. You shouldn't put much stress on the flexes any way. If there is any leaking out of the half shaft seals, change em. When the pumpkin's out, it takes like 4 minutes per side. Literally. 4 year old could do it on a good day. The input shaft seal is more involved, but if there's significant leaking there, I'd tackle that too. Most diff failures are caused by lack of fluid. |
(Post 1445159)
I didn't know they made various differentials for our model. Thanks.
