Does a Bad O2 /EGT cause RPM not to go over 4000
1999 A4 1.8t Auto - Does a Bad O2 /EGT cause RPM not to go over 4000?
stupid question but does a 1.8T have EGT where is it located? diagram? I read EGT can leave the Wastegate open causing no boost after certain RPM's I have replaced Coils/ Plugs / ICM/ MAF/ checked for leaks ...also No codes |
RE: Does a Bad O2 /EGT cause RPM not to go over 4000
no codes or jsut no cel? you might have a code stored. it sort of sounds like you're inlimp mode.
no codes...no cel.. checked them again?? how do you reset limp mode
I did reset the ECU..actually put another one in...but still the same
Only the 2.7T has EGT sensors, you can re-set limp mode just be erasing the faults. But something is causing you to go into limp mode.
Is this an automatic? |
yes Auto... but its changing through all gears... does a bad O2 cause this ?
Still check the fault memory in the gearbox and brake electronics. A faulty brake light switch can cause this, so could a faulty TR (transmission range) switch.
A bad O2 sensor would most likely throw a fault code. |
I dont have VAG can I try it with something else...? take the battery off? im sure thre are no brake light off
where is transmission range switch? also the location of transmission ecu
You need a VAG COM to test these systems.
The TR switch is the entire circuit board under the shifter assembly. The brake light switch does a lot more than just turn on the brake lights. |
