driver front axle locked up
Old Aug 28, 2011 | 04:15 PM
mzo0163's Avatar
Default driver front axle locked up
Im replacing the outer cv boot on the driver side. When hammering the joint back together after swaping the boot I noticed the axle does not want to spin properly now. The axle normally is able to spin freely but now when it spins it wabbles as it spins (in order for the axle to spin the whole shaft actually needs to move around slightly) and since I have not put the axle back into the spindle assembly it has the room to do that. But as soon as i put everything back together there is going to be a major issue. Im guessing somthin locked up on the inner axle joint when i was hammering the outer joint back on. Now im lost, and dont know what to do.
Old Aug 28, 2011 | 07:49 PM
mzo0163's Avatar
Well i decided to take the axle off completely and when I pulled it away from the transmission and a couple of the ball bearings fell out of the end that connects to the tranny. Any one know what the trick to getting those back in?
Old Aug 28, 2011 | 11:54 PM
ImTheDevil's Avatar
If they came out then the inner joint likely is damaged. I would rebuild the joint or replace the axle.
Old Aug 30, 2011 | 02:03 PM
mzo0163's Avatar
Well it turns out if the ***** fall out the inner cv joint you need to remove the innver cv joint from the axle and then put them back in, it is nearly impossible to put them back in while the joint is still attached to the axle. I decided to regrease everything and reinstall since the ***** and cage looked to be in good shape. Hopefully I dont notice any issues once the car is back on the road. Ive had the damn thing on jack stands the past 3 weeks now lol due to various repairs.
Old Aug 30, 2011 | 05:06 PM
cincyTT's Avatar
I'm make believe
My outer boot ripped and the ***** all hit the road. It would be safer if you just paid e $75 for another axel.
Old Aug 31, 2011 | 12:20 AM
DOC_DEPALMA's Avatar
Agreed with these other two. Going cheap on this sort of thing could get you hurt or worse. Be smart
Old Aug 31, 2011 | 09:00 AM
TaConklin's Avatar
Just replace the whole shaft
Old Aug 31, 2011 | 10:33 AM
cincyTT's Avatar
I'm make believe
Replacinging the shaft takes less time also
Old Aug 31, 2011 | 01:40 PM
mzo0163's Avatar
Well the only reason the bearings fell out in the first place was because i was hammering on the outer joint (while the axle was not perfectly straight) and it caused the inner joint to lock up. So when i took the axle off to fix the issue a couple of the ***** fell out because i really had to yank on the axle to get it off. If the axle had locked up on me while i was driving that would be a much bigger concern and I would definitely replace the inner joint. Plus from everying i have read about aftermarket axles on these cars is that they can cause issues becasue they are either cheap or they dont fit exactly. Im going to keep an eye on it once i get the car back on the road and if anything ill just replace the inner joint.
Zumajay
May 21, 2015 09:05 PM
brewder
Oct 12, 2014 08:12 AM
88notchblown
Jul 25, 2009 11:52 PM
swed
Dec 4, 2006 04:37 AM
tj19855
Oct 25, 2006 05:56 PM
