dv relocation kit for a4??
i was bored on my lunch break so i did a seach for dv relocation and every thing that it came back with was for the TT's does anyone make a kit for the A4 and would it have the same effect??
search i did https://www.audiforums.com/searchpro...mitbutton=+OK+ |
RE: dv relocation kit for a4??
The effects will be the same. You can get a pipe with a flange welded on from ebayand then just cut the TB hose and insert the pipe inside and then clamp the TB hose back on the pipe and then run a new hose across the engine bay to the intake.
What would be the benefit to a DV or BOV relocate
You can get a pipe with a flange welded on from ebay |
you want the metal one (doesnt matter what) so you can insert it in the TB hose. You cut the hose in 2 and then make 1/2 circles for the flange and then insert the pipe in the hose and clamp it down. Then route like stated above. You can get a flange for a turboxs on ebay you can use
ha i finally found one they are called bov adapter pipes not 't' pipes
http://cgi.ebay.com/ebaymotors/1-3-8...spagenameZWDVW and don't forget the blank plug http://cgi.ebay.com/ebaymotors/ws/eB...23892&rd=1 total for both 35.00 shipped ill probaly spend another 20 on hose or misc supplies total for it all 55.00 roughly |
ORIGINAL: kraylon they are called bov adapter pipes not 't' pipes |
yea i know they are the same i just thought they were called 'T' pipes like they are called in plumbing for water
| All times are GMT -4. The time now is 06:49 AM. |
