Electronic boost controller
Old May 11, 2008 | 10:01 PM
dr_zoidberg's Avatar
Default RE: Electronic boost controller
I'm gonna do the ebc, something about the smoothness and wastegate staying fully closed until later appeals to me.
With the ebc, but before I do my turbo upgrade, can I turn the boost up a little and still be safe, how much can I turn it up safely? I figure I could turn it up 1-3psi max... chip is like what, 11psi max, so I can crank with ebc to 14psi? I don't know those numbers at all, just guessing... NE ways I'd just have to let it run before I turned the car off, right? (if I don't get a turbo timer)
Old May 11, 2008 | 10:12 PM
cincyTT's Avatar
I'm make believe
chips run ~18psi depending on the chip. Just leave the boost be if you are stock until you have a chip
Old May 11, 2008 | 10:17 PM
I do have a chip (GIAC). so chip 18psi max, can I adjust to 20max?
will I even notice a different with a ebc? I think I would as the wastegate wouldn't open early right?
Old May 11, 2008 | 10:21 PM
ImTheDevil's Avatar
I've gotta think that somewhere in those boost ranges that little K03 OEM turbo is going to be going above its efficiency range and making a LOT of heat. I posted awhile back to see if anyone had a compressor map for the K03 but I didn't get a response on it. I know a lot of people are running high boost with them but I am curious as to when they peak out and begin to surge.
Old May 11, 2008 | 10:23 PM
cincyTT's Avatar
I'm make believe
Yes you can run a ko3 to 20-22psi daily. The ebc will hold the boost much longer in the powerband than with the n75
It is almost impossible to find a ko3 map. However, the little guy is able to make power up to 20-22psi, above that, not to much w/o the aid of wmi to bring the temps back down to reasonable temps.
Old May 11, 2008 | 10:30 PM
Great, thanks
I'll let you know how this goes when I do the install and such, I'll be ordering this and some brake stuff tomorrow morning
...that was "20psi is safe without watermeth" right?
Old May 11, 2008 | 10:32 PM
FASTER's Avatar
Tech Slut
isn't there any unit thats both a turbo-timer and a ebc in one? this is one of the few things i have left to buy for my car before it is done...
Old May 11, 2008 | 10:37 PM
  #18
cincyTT's Avatar
I'm make believe
Yes 20-22psi is SAFE by its self.
There are some generic ebc's on ebay that have both on them. they are around $200
Old May 12, 2008 | 06:11 AM
  #19
Jeff's Avatar
Zombie Defense Force
i have the apexi avcr and its great. on my car i was able to hold boost much longer and there are more settings on nthat thing then i know what to do with. it also has like 7 different values that you can watch, boost, throttle, ... and then n3 different ways to watch them either in numbers, graphs, or dials.
Old May 12, 2008 | 10:21 AM
  #20
FASTER's Avatar
Tech Slut
ORIGINAL: cincyTT
yea but are they good quality?
