Engine died and wont start
To start I just want to say hi! I am new to this site, but not new to forums. I have been searching for a while now to try to find out the reason for this problem and have a few ideas. I was driving home today and and my car just died. no sputtering or any warning it just stopped running, and i have not been able to start it since. My car is a 1997 a4 2.8 quatro Tomorow i am planning on scanning the computer for any codes that might have popped up. I am thinking it has something to do with a clogged fuel filter or something with fuel. if anyone has any information that could help that would be great.
check your fuses make sure the fuel pump fuse didnt blow
Could be as simple as faulty plugs. Might wanna pull one out and see if its covered in gas or is dry as a bone
Thanks guys I will check both of the things you mentioned.
when u turn the key does the car try to turn over or do u get nothing?
Spark, fuel, timing.
Could be as simple as a bad battery connection if you have no power and car doesn't crank. If the engine cranks, it could be fuse to fuel pump. Could be ECU. Saving the worst scenario for last, it could be your timing belt has snapped, which given your story fits . Assuming that you have power to the car and the fuse to the fuel pump isn't gone, I'd have someone check the timing belt ASAP and not crank the car. If the belt is snapped, turning the engine over can damage the valves further, if they already aren't toast. |
The car does turn over, and i did check the timing belt and it has not snapped. I also checked the fuse to the fuel pump and its ok. Thanks for all of the help so far. I am going tol check the spark plugs today, and change the fuel filter, hoapfully its an easy fix.
Originally Posted by Matt m
(Post 1005532)
If the car doesnt start up it still can be either. Plugs will tell more.
BTW, he has a V6 so the belt isnt a problem like the 1.8t |
(Post 1005532)
| All times are GMT -4. The time now is 08:38 AM. |
