Engine doesn't sound like it used to.
Old Aug 29, 2011 | 02:11 AM
A4 2000's Avatar
Default Engine doesn't sound like it used to.
Today I rolled the car into the garage to do a tire rotation and an oil change. I let the engine warm up and listened to how the engine was sounding and It sounded a little rough. A few months ago, it was more of a purring sound and now it's more like a diesel. This is starting to scare me because I remember the car sounding something like this a little before the timing belt broke. I should be able to go another 15k before getting another TB job done since I had it done about 45k mi ago. I'm never late on my oil changes and I always use full synthetic so I don't see how it could be an internal problem already. I can't afford another engine again, so do you guys think I should just look into selling it?
Old Aug 29, 2011 | 10:00 AM
jdahlen24's Avatar
It's a little premature to be talking about selling her before you actually know what's wrong, don't you think?
Besides, you're going to have to know what's wrong with her even if you were going to sell it. If it needs a timing belt job, and you're not going to do it before you sell it, you should do the right thing and be honest with potential buyers.
Are you getting any codes? How many miles on the engine? How long since the last timing belt job? Ever had the fuel filter replaced? How about the plugs & plug wires?
Old Aug 29, 2011 | 10:15 AM
MetalMan's Avatar
Cam chain tensioner?
Old Aug 30, 2011 | 01:35 AM
A4 2000's Avatar
-No codes
-About 100k on the engine
-Timing belt job done 45k mi ago
-Never changed fuel filter, but I don't understand how that could make the engine sound bad
-The coil packs are good, but it might be time to replace the plugs already
I'm pretty sure it's not that. I don't particularly hear noise coming from the back.
Old Aug 30, 2011 | 09:01 AM
jdahlen24's Avatar
Does it smell like it's running too rich? I wonder if the coolant temperature sensor could be on the way out.
Old Aug 30, 2011 | 01:17 PM
A4 2000's Avatar
The exhaust fumes smell clean and there's no smoke, so I don't think it's running rich. I do have a small oil leak from a seal in the front and from the crankshaft breather, maybe it opened up more causing engine noise to increase?
Old Sep 3, 2011 | 05:13 PM
A4 2000's Avatar
I put in some new plugs since it was missing a little under boost and borrowed a listening device to see where the sound was coming from. It seemed to be coming from the dampener pulley or another one around that area.
thaMink
Sep 12, 2013 11:40 AM
jssteinke
Oct 25, 2012 09:35 PM
m41n5t4y
Apr 9, 2012 03:58 AM
arneost
Jan 27, 2010 10:22 AM
KSK846
Feb 6, 2009 10:12 PM
