Engine Misfire Helpp!!
Old Feb 3, 2009 | 07:53 PM
2001A41.8T's Avatar
Question Engine Misfire Helpp!!
I went to my car one morning and it was misfiring pretty bad. So I searched the forums and deiced to change my spark plugs...did change anything. So I got a diagnostic test and it came up with this:
P16684: Random Misfire Detected
P16685: Cylinder 1 Misfired Detected
P16686: Cylinder 2 Misfired Detected
P16688: Cylinder 4 Misfired Detected
I read up some more... should I just change all of the coilpacks and if so where would be the best place to buy them?
Thanks
Old Feb 3, 2009 | 08:05 PM
rallyaudi28's Avatar
check your maf too when did you change your timming belt?
Old Feb 3, 2009 | 08:30 PM
MARKANTO13's Avatar
coil packs-try taking one known good coil and swaping it out with the ones in you car one at a time. this will tell you which ones are bad.
Old Feb 3, 2009 | 08:48 PM
ghost6303's Avatar
it would be a huge coincidence that 3/4 of your packs died at once. assuming your car is a 2001 from your name, then it doesnt have an ICM. i would look at the plugs or MAF before you go just replacing parts. do you have any other info other then the car was just running bad?
Old Feb 3, 2009 | 09:20 PM
2001A41.8T's Avatar
It also got the code
P16486: Mass or volume air flow circuit low input
Old Feb 3, 2009 | 11:05 PM
ghost6303's Avatar
a P code is Pxxxx, 4 digits. the P code for that description is P0102. im not doubting that you didnt get a code for your MAF sensor, but please clear up what codes you have. post the complete list and let us determine which are related. from the description it sounds like it could be related to the MAF, but we need to know which codes you found in there.
haydn
Apr 21, 2014 07:03 PM
TuApesta
Oct 22, 2008 03:09 PM
gsa4
Jul 30, 2007 03:37 PM
Henlow1
Jan 29, 2006 05:24 PM
dwkent
Apr 15, 2005 07:12 PM
