Engine and transmission compatability
Old Jan 14, 2013 | 12:08 AM
slyrapture's Avatar
How much does it cost for the tool? I was gonna do this tune up myself being i'm semi short on funds.
Old Jan 14, 2013 | 01:50 AM
slyrapture's Avatar
he's quoting me $160 for the tool.. And expecting me to pay for it.
Old Jan 14, 2013 | 07:33 AM
tofast2belast's Avatar
Originally Posted by redline380
it is very possible. you need an ohc valve spring compressor. however, once you take the valve keepers off, the valve could just drop into the cylinder. hope you are following me here. but the way to keep the valve from dropping into the cylinder once the keepers are removed is by getting an adapter to screw into the spark plug hole to apply shop air to the cylinder. this pressurizes the cylinder and keeps the valve without the keepers tigh to its seat. if you want to change valve seals without taking off the head, this is the only way it is possible.
yes this is correct. make sure what ever cylinder you are working on is on TDC for the Combustion stroke. another thing to do if the air pressure wont hold is to get some long string and feed it in the spark plug hole so it coils up on top of the piston. then you turn the motor to bring the piston up and hold the valve.
Old Jan 14, 2013 | 06:55 PM
slyrapture's Avatar
Does anyone know a place to get the compressor for cheap? I can't believe $160 is the cheapest. He said he has one for the vr6 and 2l for vw. Would those work for removing them? I'm just trying to find the most efficient way to do this. And he was saying the ohc valve spring compressor won't work for the intake valves.
Old Jan 15, 2013 | 01:48 AM
redline380's Avatar
Legal Moderator
heres a link to one for $130 Schley Products, Inc , 91400B Universal OHC Valve Spring Compressor and this is what it looks like. and it should work for all valves. the one he has may be for the old style heads. if its the new style vr6 or 2 liter head it should work fine. $130 for that one is pretty cheap too. I ve been looking for quite some time as i want/need one and can't cam across much for cheap. if i knew you better id almost be willing to go in on some sort of deal with you if you only need to use it once
Old Jan 15, 2013 | 06:56 PM
Slowb5's Avatar
why dont you get a 2.8 tranny? bolts up an everything, plus its way more beefy and can handle whatever *loosely speaking* you can throw at it.
jackson101
Feb 12, 2012 10:20 AM
RedWabbit
Jan 3, 2012 11:27 PM
deek van-norville
Jun 30, 2010 03:16 PM
unnaturallyaspirated
Feb 22, 2008 11:04 PM
aikibil
Apr 25, 2007 12:08 PM
