Engire sometimes starts running really rough and check engine light flashes
Old Mar 1, 2011 | 04:05 PM
BT5150's Avatar
Default Engire sometimes starts running really rough and check engine light flashes
A couple of days ago, I was driving when the engine suddenly started running really rough, especially around 2,000 rpm, the whole car was shaking. If I accellerated, some of the roughness went away, but it accelerated really sluggishly. At the same time, the check engine light started flashing. Mysteriously, after maybe 5 minutes of this, it went away and the car was fine. Since then, this has happened 3 more times and the lasts time it lasted for more like 15 minutes. Any ideas as to what could be causing this?
Old Mar 1, 2011 | 04:45 PM
row503's Avatar
check your coil packs.
JoBuNY's Avatar
Check your coil packs & spark plugs.
Old Mar 1, 2011 | 04:55 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
You're getting a misfire. If you have vag com scan for codes and see which cylinder is misfiring, swap the coilpack with a different cylinder and see if the misfire follows the coil pack. If its not the coil pack its most likely the ignition control module.
Old Mar 1, 2011 | 06:18 PM
ImTheDevil's Avatar
And for the love of god STOP DRIVING WHEN THIS HAPPENS. search "misfiring" and read about the problems associated with it.
Old Mar 1, 2011 | 07:53 PM
zero415's Avatar
Default 2.8 v6 Audi A4 help
best of luck to you.. you seem to be getting more help then i am
Old Mar 1, 2011 | 08:11 PM
ImTheDevil's Avatar
^^^your 2.8 isn't known for misfires, and those faults that typically cause them, you've handled already.
Old Mar 1, 2011 | 09:47 PM
BT5150's Avatar
I did some searching, it sounds as if replacing the coils isn't that hard to do, can anyone point me in the direction of a diy for this?
Old Mar 1, 2011 | 09:56 PM
Remove engine cover, unplug them, unbolt them, replace them.
Old Mar 1, 2011 | 11:42 PM
morpheous's Avatar
waiting for you to pm me your cell,so we can setup a seafoam treatment session....
cdpoppert
Apr 19, 2010 12:42 PM
OnlystreetraceAWD
Dec 10, 2008 12:18 AM
Tyrell
Jul 8, 2008 07:30 PM
Willfulone
Apr 7, 2006 02:11 AM
