ESP/ABS Lights on
I got into a accident back in January but have just gotten it back in working order. I cleared all the codes yesterday before I took it out to make sure everything is working but keep getting this one code along with the ESP and ABS lights coming on.
1 Fault Found:
00778 - Steering Angle Sensor (G85)
27-10 - Implausible Signal - Intermittent
Currently the car needs a bit of an alignment as the steering wheel is cranked about 20 degrees to the left while the wheels are going straight. Is there a way for me to reset the sensor to this positioning for now? I have to drive back to school 200 miles away tomorrow so if I can get it working properly tonight or tomorrow morning that would be the best.
1 Fault Found:
Why do you need your ABS and ESP back??? I've been driving without them for months. I have a bad ABS sensor which throws both off. Just get your alignment issues checked and do everything mechanically, then worry about the sensor. It may have even been damaged in the crash and need replacement.
I got the alignment done quickly last night but they found out that the upper rear control arms are bent a bit so thats throwing the rear off. When i get back home in a month I'll replace the arms and then take it for a full alignment.
nize
Jun 21, 2013 01:16 PM
L_U_D_I_AAudi
Jun 3, 2012 04:09 PM
mypreludeisred
Aug 9, 2006 11:08 PM
lilman05
Apr 27, 2006 02:56 AM
lilman05
Apr 25, 2006 10:04 PM
