Experts please help fast abs module!
Old Sep 17, 2009 | 02:15 AM
vandynamics's Avatar
Default Experts please help fast abs module!
my abs module has the code
8eo 614 111m
my question is will 8eo 614 111p work if im trying to clear an ABS light?
is P interchangeable with M?!
THANK YOU!@@
Old Sep 17, 2009 | 06:46 AM
Andrew149's Avatar
well i looked on wiki and the code didnt come up is your abs light blinking if so you haft to send it in to get rebuild or you can call shokan and you haft to give there the numbers off your module
Old Sep 17, 2009 | 01:47 PM
yeah i think im going to go ahead buy it and try to see if it works.
my suspicion is that is part number refers directly to the brake block but the Bosch sensor is probably the same. Ill be using only the sensor so we will see what happens i will let everyone know if there is cross compatibility between 111m & 111p
stang32
Feb 23, 2014 10:53 AM
AudiCoupeV6
Dec 4, 2008 01:21 AM
southcoast
Jan 10, 2007 07:31 AM
ininkus1
Sep 10, 2006 01:11 PM
JG
Mar 31, 2006 09:15 PM
