Fan clutch test?
Old Mar 8, 2011 | 10:39 PM
Mad Cow's Avatar
Default Fan clutch test?
Is there a way to test a fan clutch to see if it's working properly? I have a suspicion mine is locking up when it shouldn't because I hear a really loud whooshing sound whenever I rev my motor past 1k rpm that sounds very similar to other cars' fans.
Old Mar 8, 2011 | 11:03 PM
theflash's Avatar
Hmm. In my experience, the problem is they don't lock up when the viscous fan clutch goes. The test is hard to judge, but the idea is that you start the car and feel the air flow being produced. Then wait until the car heats up, or take it around the block.. either way get it up to operating temp. Now test the air flow. It should be much harder, if not it's toast.
Edit, the only time I've seen one "lock up" was when I discoverd the previous owner had installed a 1.8t fan blade instead of a 2.8 blade. They turn opposite ways. Soon there was fan blade shrapnel in the radiator. Not awesome.
Old Mar 9, 2011 | 01:04 PM
99A4NOW's Avatar
Just to let you know, I had mine lock up semi permanently about a month ago. It was very loud when reving the engine.... then it broke into a million pieces. Definately get it fixed/replaced soon. It's not designed to fully spin with the speed of the motor.
Old Aug 17, 2011 | 11:21 PM
raudi28's Avatar
dont mean to bring back old threads but i have this same problem with my car, my fans are loud as f*** right when i step on the gas. replaced the fan clutch and it didnt do a thing. clutch works fine they are just loud. anyone know what else could cause this?? gets louder as rpm's increase if that helps. 2000 2.8 30v
Super92
Nov 2, 2014 09:52 AM
powersmokin
Apr 10, 2008 10:49 AM
Ninam
Dec 4, 2007 09:50 AM
operator
Nov 1, 2007 06:57 PM
The Bishop
Nov 30, 2006 06:03 PM
