Fault Code: P1101 & P1106 - PICs and Video, Car & Dash Go Dead
Ok, I'm back....
Overview: 1997 Audi A4 Quattro 2.8L 163K miles, 5spd.
I did some work over the weekend, got the car to run. Now I'm faced with two fault codes: P1101 & P1106.
Scenario - start the car and I get this image (see below). What does 1n1 mean in the odometer?
Second Scenario - driving the car (watch video) the dash goes dead, then comes back to life. Power to engine is on. Link to video: https://picasaweb.google.com/1099319...20912403812786
So, what are the fault codes? And, why do my gauges go dead while driving? Loose ground wire somewhere?
Thanks for your help!
IIRC, P1101 and P1106 are O2 sensor codes, though I can't recall which ones. The 1in1 you're seeing below the odo is a service interval light, basically an idiot light reminding you to change the oil. You can ignore it like most of us, or if it bugs you search for "reset service interval light" and you should be able to find a DIY to reset it. Its a certain combination of pushing buttons and turning the key I think. You can also reset it with Vag-COM if you have that handy.
Any thoughts on the gauge problem? Seems like a loose wire or could it be a bad fuse or relay? The car does stutter when the gauges go in and out.
I'll check on those things tomorrow. Was able to drive it home from the office after installing a new battery. Still don't trust the electrical system.
New Battery has helped. I did not run the a/c on my way into work and noticed that my charge stayed above 12. Anything below 12 and the dash goes crazy and the car cuts out.
It's most likely air-fuel mixture (vacuum and fuel delivery) and the electrical system. I'm going to have some more fun this weekend. Thankfully it hasn't hit 100 yet in the mornings for the daily commute.
Check by looking for water entry. Check above the driver's footwell too where the relay panel is.
Then check your charging system.
I'll be looking into the fuses tonight when I get home. Alternator will be this weekend again.
Still Not Working :(
Replaced the Alternator. Car will not charge.
I ran the car for two hours last night. The voltmeter would show 8-12 and periodically the car would stall.
Any ideas? I'm beginning to loathe this vehicle.
Checked the box under the hood, no water. Checked the fuses on the side of the dash, all good.
Am I looking for a loose wire? Bad Ground? What else could it be?
