Few codes
Old Mar 19, 2009 | 01:25 AM
YoungGentleman86's Avatar
Default Few codes
Hey guys I'm back with a new (well 113,000miles) motor, fresh control arms and drive axles.
Anyway to the issue. after the motor was installed i check engine light still (didnt get to check before). Car ran great but i had the plugs replaced the same time i did the control arms and noticed that the car has a rougher idle all of a sudden.
Went in to autozone and had them scan it.
MAF sensor
throttle position sensor
and misfire in cylinders 1 and 4
.... any ideas?
also after the new drive axles... the car runs good but when i get on the brake i get a slight buzzing sound and feel from the front left and checked... the wheel was sensed to be moving slower than the rest... checked the abs sensor on it and it fixed it for the most part, except when the car is creep very slow and i get on the brakes. The mechanic and another guy i was having a convo with said for me to give it abit and it should correct itself (guy said same happened to his car before... he wasnt at the shop... just some guy i was having a convo with at school).
Old Mar 19, 2009 | 03:06 AM
Audi_Skydiver's Avatar
Do you have the actual codes for the car?
Josh
Old Mar 19, 2009 | 03:07 AM
Also double check ALL the connections for the motor around the MAF area.
josh
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
