it finaly happened, DTCs appeared.
Old Dec 30, 2007 | 11:46 AM
gio gio's Avatar
Default it finaly happened, DTCs appeared.
Marry Christmas,
miracles realy happen:
for 9 month a owe an A4, 1997, 1.8t quattro. it consumes a lot of gas - 13 mpg in a city, but scanning with vag-com did not show any problems, different tests (O2, MAF ....) according the manual returned values as they should be when the car is ok, no diagnostic problems.
today miracle came, i got back home, parked the car, wanted to get a camera, to make photos for an ad, because i am going to sell this strange VEHICLE (swop to HONDA). in5 minutes i was back and tried tostart the car, but it did not aftercrancking for about 5 sec. for the second try it started but the check engine came on. i got realy happy . got the vag com, scaned and got the following:
Address 01: Engine Labels: 8D0-907-559-AEB.LBL
Part No: 8D0 907 558 M
Component: 1.8L R4/5VT MOTR AT D01
Coding: 06251
Shop #: WSC 08659
6 Faults Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 35-10 - - - Intermittent
17645 - Fuel Injector for Cylinder 1 (N30): Open Circuit
P1237 - 35-10 - - - Intermittent
17646 - Fuel Injector for Cylinder 2 (N31): Open Circuit
P1238 - 35-10 - - - Intermittent
17647 - Fuel Injector for Cylinder 3 (N32): Open Circuit
P1239 - 35-10 - - - Intermittent
17648 - Fuel Injector for Cylinder 4 (N33): Open Circuit
P1240 - 35-10 - - - Intermittent
Readiness: 0000 0000
i cleared the codes, started the car, no problems. could any1 comment or give his idea. i would realy appreciate it, may be even change my mind about selling this car off
Marry Christmas and thank you very much.
Old Dec 30, 2007 | 12:21 PM
CoastalA4's Avatar
Default RE: it finaly happened, DTCs appeared.
Codes never appeared after you conducted your tests??? The "open circuits" are the codes resulting from removing your connectors (each injector and the boost valve). The only assumed real code, for the MAF, could explain your poor gas mileage. Try cleaning the MAF, IF you're not satisfied with the mileage or performance and drive. Of course, the mileage could be a compliment of a happy A4 driver!
As to why they didn't appear earlier, that would be a question for VAG-Com folks. They may have more insight.
Old Dec 30, 2007 | 12:37 PM
gio gio's Avatar
there have never been any codes before today. today, when i cleared the codes, i started the car again, no codes. and i have not unplaged anything after i parked the car, and have not fixed anything after the codes appeared. and before the parking there where no codes. mistics, seems i am better with honda, at least i had two ones before the Audi, all i did during the three years i had them, was changing oil, coolant and some bearings. but this audi is challenging with his strange gas and codes behavior. concerning the MAF, i tested it while driving and the readings were perfect according the test published on the vag-com site - 130.28 g/sec at 6360 rpm. in any case i will try to clean it. do i need special detergent for that?
I bombed vag-com guys about my problems with the codes, they gave up, talked i should reffer to the audi manual. but the thing is that at audi service center i tested the car several times, no DTC again and they talked that the readings were perfect.
Old Jan 2, 2008 | 03:50 PM
gio gio's Avatar
it seems no1 has any idea about a strange behaviour of my audi. i am for honda. I like challengies, but not mistycs.
PacificA4
Jun 7, 2012 05:30 PM
v8ramair
B7 Models
May 14, 2011 03:49 PM
Aud1A6
Jan 12, 2011 02:26 PM
Audified
Feb 12, 2008 05:55 PM
bvass
Jul 28, 2005 10:51 PM
