Front left bulb is on but not blinking, NEED HELP!!!! PLEASE
Old Jan 1, 2009 | 12:45 PM
10kRedline's Avatar
Unhappy Front left bulb is on but not blinking, NEED HELP!!!! PLEASE
Ok, my front left blinker bulb is on but not blinking. It's not the bulb problem I guess. When I turn the left signal, the whole left turn signal blinks FAST ( like a ricer's car ). How do you fix this, I've searched all around.
Old Jan 1, 2009 | 12:56 PM
akielb's Avatar
Does the left rear blink?
If that doesn't, then check the manual and figure out which Fuse has blown. Left and right are on two different fuses
Old Jan 1, 2009 | 01:12 PM
Jc61990's Avatar
when it blinks fast that means a bulb is out, so like akielb said check the rear.
and if its on, you might have the parking lights on,
Old Jan 1, 2009 | 03:20 PM
jskinny's Avatar
have you switched bulbs yet to make sure its not just burned out? there are two filaments inside the bulb so the blinking one might just be burned out. happened to me the opposite way, it was blinking but wouldnt turn on constantly, that was the problem
Old Jan 7, 2009 | 02:38 AM
10kRedline's Avatar
Well, all the lights are on but it's not blinking....need new bulbs?
Old Jan 7, 2009 | 12:49 PM
CCA4's Avatar
yeah usually when it blinks fast like that, one of the bulbs on that side is burned out. no sense in replacing all of them, just figure out which one is blown up and replace it.
Old Jan 7, 2009 | 02:52 PM
Jc61990's Avatar
hmm just curious. if the sidemarker bulb goes out, will it cause the lights to blink fast too??
Old Jan 7, 2009 | 09:14 PM
Dallas09's Avatar
They are dual-filament bulbs in the front, so the parking lights can still work but not the blinker.
Old Jan 7, 2009 | 10:44 PM
somebody5788's Avatar
Ya its just a bulb. Unless you have a corroded terminal but I doubt it. If neither blinked at all it would be the relay. Which mine did last week but fixed itself
bcgreen
Apr 9, 2013 10:03 AM
allroadftw
Jun 14, 2012 12:48 AM
A4driver17
Dec 17, 2011 08:55 AM
wutafobbb
Apr 15, 2008 10:23 PM
jimmyp63
Feb 8, 2005 05:30 PM
