Front right wheel squeaks
My front right wheel squeaks between 5 and 20 mph. I took it to my mechanic, he cant hear anything and says it drives just fine. Some days it is louder than others. I think it is the wheel bearing, any thoughts????
If you can recreate the sqeak this way, its a control arm and not a wheel bearing. If its your wheel bearing it should be more noticeable when a load is placed on that wheel, when cornering for example. Take an on/off ramp at speed so that the wheel in question is the outside wheel and see if you hear the squeak.
And, one time i was in my driveway recreating the sound of the wheel turning for my dad to see, and my engine started smoking.
sounds like two seperate problems to me. Take off the wheel on the corner where the squeak is and get in there with a pry bar or a big screw driver, and start moving the control arms around. there should be little to no play in them.
