Front tire noise
Old 03-03-2004, 02:04 PM
A4izzy's Avatar
Default Front tire noise
I have a 97 A4 1.8 Quattro and when creeping slowly, I hear a grinding (semi soft popping) sound. What problems could this be? is it something I can handle myself?
<img border="0" src=smileys/smiley7.gif border="0">
Old 03-03-2004, 07:00 PM
brrman's Avatar
does it get worse when turning?
Could be a bad bad control arm (the ball joint - not the bushing)
Could be something stuck in your brakes, could be a bad CV joint...
Old 03-04-2004, 02:23 PM
A4izzy's Avatar
It is most noticeable when backing out of my garage straight, and when I first start off forward. After that I probably cannot hear it. I can slightly "feel" it in the steering too.
Old 03-04-2004, 03:14 PM
brrman's Avatar
are your brake pads secure? They may be clanking around in your caliper. Most pads have some sort of adhesive on the back of them - after a while it can stop working and the pad will float freely in the caliper until you brake enough to seat them.
You sure its coming from the wheels?
Old 03-04-2004, 07:31 PM
A4izzy's Avatar
I'm pretty sure. Will applying the brakes aggresively reattach the adhesive? I've already taken the car in once for them to check. The weather truned really cold and they dismissed it saying they couldn't find anything (and a bill of $97.00).
Old 03-05-2004, 03:06 PM
brrman's Avatar
once that adhesive lets the pad off - it normally fills with brake dust and will no longer stick... kinda like if you dropped a fresh piece of masking tape in a dustbin... Applying the brakes will seat the pads, but it won't keep them there indefinitely.
do your brakes squeak at all?
Old 03-07-2004, 12:48 AM
jeeptjs's Avatar
i'd definitly check your brakes to.
Mjacobson
05-26-2015 03:52 AM
Mjacobson
Audi Q7
04-15-2015 09:52 PM
audi28XWJ
02-27-2012 03:33 PM
jimmysA4T
08-03-2005 04:48 AM
General Jackson
08-01-2005 01:23 PM
Quick Reply: Front tire noise
