Fuck.
Old May 3, 2011 | 04:40 PM
NickBroderick's Avatar
Tearing out the headliner isn't bad at all, at least the second time around. I really just want to replace the sunroof with a carbon fiber insert right now and have that painted. I rarely used it anyway.
Old May 3, 2011 | 05:31 PM
adrianl_888's Avatar
You'll forgive me if I don't pat you on the back for being "ballsy"
You just come across as vulgar and stupid.
Old May 3, 2011 | 05:59 PM
rcheing's Avatar
Thumbs down
These new members think they know everything...and this is his first post? Wow!
Old May 3, 2011 | 06:02 PM
ImTheDevil's Avatar
To be honest, this thread isn't getting very far. How about everyone just focuses on the topic?
Old May 3, 2011 | 07:00 PM
Andrew149's Avatar
best thing to do is take it apart watch what parts are moving and what is not moving and troubleshot from there
Old May 3, 2011 | 07:08 PM
Skythe's Avatar
Nick, I'm thinking it's the plastic track that covers the actual track that's falling apart on yours. It's broken on mine and my sunroof gets stuck. I thought you had a similar issue before, but it was a little different. A new one costs about $1500; used...you don't really know what you're getting. I have a couple spare sunroofs I'm determined to work on this summer when I'm home from school. Maybe I'll sell you one cheap
Question though--why go for the painted sunroof delete instead of having a window above your head to let sun through? It'd weigh a little less, but it can't be that much.
Old May 3, 2011 | 07:29 PM
airguard350's Avatar
Tech Guru
**** YOU! I'm a new member AND I KNOW ******* EVERYTHING. NOW I'M JUST GOING TO MAKE MY FIRST 15 POSTS INSULTS TO DEMONSTRATE MY SUPERIOR INTELLECT AND CAR PROWESS!!!! BWAHAHAHAHAHA I HAVE NO REAL FRIENDS.
That's what most new members think.
Old May 3, 2011 | 07:39 PM
  #18
Audi Tek's Avatar
Tech Certified
Just like Auditech said.... operate the motor with it disconnected from the sunroof frame and make sure the gear turns.
Then make sure the switch is in the closed position. Then hand crank the sunroof fully closed and install motor.
This is setting it up for the zero position.
If you can hand crank the sunroof fully open and closed and feel no resistance your cables are fine.
Old May 3, 2011 | 08:15 PM
  #19
CCA4's Avatar
Why don't you put your tiny little internet ***** back in your purse until you get to know the senior members a little more.
Old May 3, 2011 | 08:35 PM
  #20
Audisaurus's Avatar
Im not sure if this is controlled by the Central locker but when i do the key in the door and hold it to put my windows up it seems it only goes 3/4 of the way? I also saw a a4 where his **** wasnt greased and it didnt let it shut right.
