Fuel Problem
Hi, I have recently purchased a 2000 A4 2.5 TDI V6, problem is that when fuel gauge read 1/4 tank and computer said 35 miles left it ran out of fuel, what is the most likely cause the tank sender or the computer ?? HELP PLEASE
I would suspect a bad sender unit in the fuel tank. they get gummed up from the diesel fuel , can stick or cause false readings.
Unfortunately we dont get to see these engines here in the States so could not be posative. Also one more thing , there is a fuel sender adaption that have a effect on the readings. Most likly the sender will need replacement. |
Thanks for your help
| All times are GMT -4. The time now is 06:37 AM. |
