Going to replace most of the front end...need some advice/suggestions
Old Jul 20, 2010 | 01:43 AM
A4 2000's Avatar
Default Going to replace most of the front end...need some advice/suggestions
I finally came up on a little extra cash after a long dry spout from when I replaced my engine. My major concern right now is to replace the passenger side front axle since the inner cv boot is torn and now the car makes a grinding sound with occasional vibration which makes me nervous since I have to commute 100 mi. + to work 5 days a week. I wanted to ask first off if it's difficult to replace the axles yourself? Is there a trick to lining up the connection to the tranny/differential? I know I need a 12 point bit connected to a socket, but what size?(I would have to buy one) Also, where the spline connects to the hub, I'm guessing I will also need that one tool that pushes it out. I'm going to put a new one in on the other side too since I want everything new and for peace of mind. Any help with the axle mainly would be great. Any other suggestions are welcome too. Thanks.
Here's a list of what's going to be done:
resurface f rotors
new pads
2 new axles
2 new bearings
complete f upper and lower CA kit
4 new tires possibly with new rims
And of course an alignment after all the work is done
Old Jul 20, 2010 | 02:35 AM
g2turbo7's Avatar
Worst part about the axles is if there's any rust. Last axles i took out of an A4 required two guys and some time to remove. No fun, but got it done. Normally, just loosen the 14mm socket nut from the hub. I think the 12pts are 8mm. Straight forward really.
The axle can be dangerous when the grease runs out. Worst case it will start binding up and seizing-- not something to take too chance on a long commute.
Wheel bearings on the other hand are MUCH harder than axles (which aren't a big deal). It requires either a special bearing toolset and/or a shop press. I have both and it's still challenging. The uprights need to be removed, too. Plan on a full weekend of work with the right tools.
Old Jul 20, 2010 | 08:00 AM
chocalotstarfish's Avatar
Super Moderator
If you need an axle out just have Bri drive your car.
Old Jul 20, 2010 | 08:15 AM
onepoint8tee's Avatar
The hardest part about doing the passanger side axle is getting the heat shield off/on so you can get to the bolts, and making sure the gasket is perfectly lined up. But it's nothing compared to r/r control arms. If by resurfface the rotrors you mean using a sanding wheel to buff away corrosion or glaze then ok, but you'll probably do more harm than good if you are trying to actualy shave away /reveal a new layer of surface. That procedure is sort of outdated... It makes the rotor more likely to warp because it reduces heat distribution/ disipation properties. Have a shop press your hubs and bearings out/in. Don't even put yourself through the misery that is using a hub shark/handheld sort of puller/press.
Old Jul 20, 2010 | 01:14 PM
A4 2000's Avatar
Ok. Thanks for the advice so far.
Old Jul 20, 2010 | 11:06 PM
A4 2000's Avatar
I was thinking that I might just have a shop do the axles and switch out the bearings all at once. It just seems like less of a hassle
Old Jul 21, 2010 | 12:13 AM
Less of a hassle for your delicate hands, big hassle on your wallet
Old Jul 21, 2010 | 02:41 AM
A4 2000's Avatar
Well for labor they're charging $60 per axle so I don't know. I've just never done this before so I'm a little scared to mess something up and I'd have to go buy some more tools to do it. That's what I meant by a hassle.
Old Jul 21, 2010 | 02:47 AM
I know what you mean... I'd like to know what their quote is to do the wheel bearings.
Old Jul 21, 2010 | 09:10 AM
A4 2000's Avatar
I'm going to call them again today to see how much more it would be doing the bearings too. I'll post up how much as soon as I find out.
