gt2x elim
Old Feb 11, 2008 | 06:37 PM
cincyTT's Avatar
I'm make believe
Default RE: gt2x elim
If the PC-16 is the 380cc file, then yes. That is unless there is another 380cc file available. You will have to limit the boost to 22psi so you dont over spin the turbo. You can do that with a mbc/ebc if you bypass the n75. YOu may even be able to get it tuned for less boost.
If done right, Mya4T should see around 250whp with his AEB car and plans for w/m. For awd, 230awhp would be doable on boost alone. The point of using this turbo is stock like spool with a large amount of low end tq all while still holding power where the ko4-15 cant.
Old Feb 11, 2008 | 06:41 PM
qUaTtRoA4's Avatar
nice....just what I wanted to know!....
thanks cincy, good info!
Old Feb 11, 2008 | 10:16 PM
Mya4T's Avatar
cincy thank you for the info. what should i do with my revo chip now just sell it? also where is the best place to get a gt2x? and how much you think it will run me total?
Old Feb 11, 2008 | 11:33 PM
cincyTT's Avatar
I'm make believe
You could always try to run the 440cc file with the elim or trade it for another ecu. Im not sure whats all availble from them. You should contact the local dealer to see what they can do for you first. Not sure wheres the cheapest place to get the elim, you can try boostfactory, kineticmotorsports, renn-art, or just strait from atp
Old Feb 11, 2008 | 11:50 PM
A4speed's Avatar
Unitronics or CTAPP would actually be your best options for you, they have the best tunes for the B5 (for BT setups).
Old Feb 12, 2008 | 12:42 AM
chaos92287's Avatar
ORIGINAL: cincyTT
pc16 is a 310cc tune. pretty sure j31 is a 380cc tune
Old Feb 12, 2008 | 12:53 AM
cincyTT's Avatar
I'm make believe
There you go. Some many names. I like how everyone now goes by CC files and not stupid names.
Old Feb 12, 2008 | 01:00 AM
  #18
chaos92287's Avatar
seriously, makes it so much simpler and easier to remember
Old Feb 12, 2008 | 01:20 AM
  #19
scotts custom's Avatar
depends on if you install it all yourself or not and what you already have on your car...
- elim = around $1000-$1200
-fmic = $400-$1000
-tune = $400-$500
-all little necessites = around $100?
-instalation = ? (a lot)
there is more that you will probably need, but im too tired now
im not sure if these #'s are correct, but around there im guessing
Old Feb 12, 2008 | 02:05 AM
  #20
A4speed's Avatar
a BT tune will actually cost you around $700-900.
