hazard switch, fog light switch. cup holder removal
Old 02-28-2010, 10:59 PM
holdin16's Avatar
Member
Default hazard switch, fog light switch. cup holder removal
so i want to take out the the switches and cup holder listened in the tittle out. everything about the head unit. i was wonder if it was possible to remove and everything and if so then how. thanks for any help
Old 02-28-2010, 11:34 PM
auditech79's Avatar
You have to remove the radio to get the hazard switch out, same with the fog light switch and cup holder. To do that you need the radio removal keys.
Old 02-28-2010, 11:43 PM
holdin16's Avatar
Member
the radio is alright out. i went from the stock doule din to a single din tv. and want to put two gauges above the tv. but there isnt enough spae to fit in between the radio and switchs. can all that come out entirely in order to fit those gauges there? and also does the trunk handle where the key hole is come off the trunk? or is it molded onto the trunk? thanbks again
Old 02-28-2010, 11:49 PM
auditech79's Avatar
Well if the radio is already out, reach your hand up there and depress the two metal tabs and push them out from the back.
Why on earth would you want to remove the button on the trunk? Yes it comes off, but you have to remove everything inside the trunk lid to get at it.
Old 03-01-2010, 12:02 AM
holdin16's Avatar
Member
mine is all scratched up so im getting that piece re painted
Old 03-01-2010, 01:13 AM
BaconBait's Avatar
On my 2000 I just pulled the cup holder out halfway and stuck my finger behind the plate and it popped right off. I did need pliers to get the hazard switch out though.
Kuyt
11-07-2014 06:18 PM
BarbaraSymonds
05-01-2013 01:51 PM
Andy_G
08-15-2012 06:38 PM
kduznetsov
04-10-2011 10:47 PM
ima_slap_joO
05-31-2008 09:55 PM
Quick Reply: hazard switch, fog light switch. cup holder removal
