AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   HELP, engine coolant keeps leaking out! (https://www.audiforums.com/forum/b5-models-69/help-engine-coolant-keeps-leaking-out-148401/)
austindgarner Apr 2, 2010 09:23 AM
I have to replace my engine coolant every other day. It seems to leak when im not driving it. I saw a steady stream of coolant leaking from right behind the engine on the bottum, it looked like a little metal piece that it was coming out of. What would that be and what could i do to fix the problem/
chocalotstarfish Apr 2, 2010 09:28 AM
When mine was leaking real bad last fall it appeared to be coming out of the same area you are talking about but the leak was behind the top of the motor towards the firewall there is some kind of reservoir or something back there that was cracked and just dumping fluid! Make sure that you find where the leak is, might just be a hose or something popped off.
Tourbo24 Apr 2, 2010 01:20 PM
when mine was leaking out it was out of the water pump
cmacelo121 Apr 2, 2010 01:49 PM
check your coolant tank audis coolant tank tend to crack due to the age of the car.
djMichaels Apr 2, 2010 05:13 PM
Well since you said it's at the back of the engine it sounds like it could be your coolant flange. I had a similar issue after I drove my car cross country. I wasn't loosing that much g12 but still a decent amount.
austindgarner Apr 3, 2010 10:54 AM
coolant leak from behind engine, line going into turbo
Help, there is a hard metal line that goes into the turbo and works its way along side the engine and to the back. Its leaking in the back. i put my hand there and i can feel it dripping. what would be happening
