Help with finding a PVC system, replacement kit & coolant flange
I need help, looking for a complete, PCV replacement kit and coolant Flange for my 2001 Audi A4 1.8T AWM :) I looked on esctunning and was completely confused with the kits they had on it. someone, please assist. :confused:
If you want to replace the entire PCV system then I would suggest 034's silicone breather kit.
Breather Hose Kit, AUG/AWM/AMB B5/B6 Audi A4 & Volkswagen Passat 1.8T, Reinforced Silicone - 034Motorsport | Performance Parts for Audi, Porsche, and Volkswagen https://www.034motorsport.com/oscthu...r_Hose_Kit.jpg If you don't want to spend that much, then you could get by with replacing the block elbow and T fitting as those are the common leak points. Block elbow: 06A 103 213F T-fitting: 06A 103 247 You should be able to get those two parts for less than $50. Make sure to get a new o-ring for the block elbow. Also, I wouldn't call those two parts easy to replace. You'll be working in very tight spaces beneath the intake manifold and will have to remove a couple of the pesky one time use clamps. |
Thanks basedrifter :)
what about the coolant flange? :confused: |
AWM OEM coolant flange: 058121132C
Flange to head o-ring: 037121687 Flange to coolant pipe o-ring: 058121687 |
Originally Posted by BaseDrifter
(Post 1450773)
Flange to head o-ring: 037121687 Flange to coolant pipe o-ring: 058121687 awesome! Thanks man. I added those part numbers to my Reinforced Silicone Breather Hose Kit. Total is $142.33 not bad, considering how much, esctunning is charging for it's kits and OEM kits, that's not even silicone. :) Can you vouch for this kit? did you install it in your B5? :) |
Yes, I installed the 034 breather in my car a few weeks ago.
I wrote a DIY article here: https://www.audiforums.com/forum/diy...-early-199692/ It's written for an AEB, so your AWM will be a bit different, but the same concepts apply. |
(Post 1450776)
I wrote a DIY article here: https://www.audiforums.com/forum/diy...-early-199692/ It's written for an AEB, so your AWM will be a bit different, but the same concepts apply. I'm leaking oil and i didn't know from where, until i finally got my Russian mechanic to finally look at it and tell me, where the oil is leaking. This after i got my rear main seal, valve cover gasket, half moon seal and the gasket seal and Both front camshaft seals, replaced and still was leaking oil!! So i hope this settles the oil leaking issue. ;) is there anything else i should replace, while replacing the PCV system? Do you know of a vacuum hose kit? maybe i should do that, while I'm at it? please point me to a kit on the same site if you can, being i prefer to buy, everything at once on the same site if i can. |
It's always a good idea to check the vacuum lines and replace them with silicone. I believe 3mm for the smaller lines and 5mm for the larger ones.
ECS and 034 should both carry vacuum hose. |
(Post 1450778)
No, there are no kits. Buy some tubing, remove the old line, cut the new one the same length, reinstall.
