HELP!!! Headlights dont work
Old Jun 4, 2009 | 08:54 PM
gDmM@NnY's Avatar
Default HELP!!! Headlights dont work
my headlights arent turning on
what could it be?
noob here
Old Jun 5, 2009 | 11:45 AM
ghost6303's Avatar
obviously.
for future reference always give information about your vehicle when you post. 11 words isnt enough information for us to give you an answer.
Old Jun 5, 2009 | 11:50 PM
ImTheDevil's Avatar
Basically yeah you should go to your user control panel and create a signature including your year, model, engine, drivetrain, and transmission (such as 2001 A4 2.8 30v qm, where qm is quattro/manual). It'll help a lot.
That being said in this case you probably have a bad combination switch (headlight switch) - it's very common. The usual symptoms are parking lights work but not headlight low beams. If you pull on the stalk the high beams will light but that's it. That's a bad switch, which runs about $158 from www.ecstuning.com. Replacing it involves removing the airbag and steering wheel. It's not terribly hard by any means but there are things to keep in mind when dealing with airbags. Buzz me in a reply here or better, a PM and I can discuss it with you (it's been talked about in the forums a lot and probably doesn't need to be covered on-air again).
Old Jun 6, 2009 | 09:54 PM
gDmM@NnY's Avatar
thanx for the help thats exactly what it is. im gonna look into it
Old Jun 7, 2009 | 02:57 AM
kayakman13's Avatar
www.audidiy.com
Never ceases to amaze me how many writeups there are at that site. They have an excellent one for the headlight switch that I used two weeks ago.
Old Jun 8, 2009 | 12:53 AM
sdboarder84's Avatar
I have this same problem but it is just the driver side head light and sometimes the signal does not work. Could this be my problem or something else
Old Jun 8, 2009 | 04:31 PM
kayakman13's Avatar
You probably have a worse problem. If its the whole headlight, check the connections. Fuses? Bulbs? Unlikely, but cheap to check and fix. Cross your fingers and hope its not a wiring gremlin.
Old Jun 9, 2009 | 09:06 PM
it is just the low beam, the high beam still works and the signal usually does
Old Jun 9, 2009 | 09:13 PM
ImTheDevil's Avatar
Headlight and turn signal typically are separate issues. Check your fuse panel - each low beam has it's own fuse.
jayj93pgt
Jun 29, 2009 01:55 PM
gDmM@NnY
Jun 21, 2009 08:45 PM
hedman09
May 18, 2009 02:34 PM
jaymarsuperstar
Jul 14, 2007 09:19 AM
