Help! Hesitation/Stutter. Fuel Problem
Old Jul 16, 2009 | 03:46 PM
Audiguy271's Avatar
Default Help! Hesitation/Stutter. Fuel Problem
Ok so heres the deal. My 1999.5 A4 with GTRS turbo and everything was recently finished. For a little bit anytime you hit around 10 PSI it would stutter or hesitate real bad. We switched out the MAF to the correct VR6 MAF and the problem went away. I just want to know if there is anything else that could be causing this though and If the car is safe to drive hard. My mechanic thought I might need a bigger fuel pump and told me to go past 4k rpms. I just want to some input on whether or not going past 4k rpms could damage something expensive like blowing a rod or piston?
Old Jul 16, 2009 | 05:59 PM
audi guru's Avatar
revving the engine ppast 4k rpms?
Old Jul 18, 2009 | 08:54 AM
Audiguy271's Avatar
Not currently for fear of damaging something. Plus im out of town right now and not even driving the car.
Old Nov 2, 2009 | 05:07 PM
N*E*R*D*'s Avatar
i am having the same problem car runs strong up to about 4k rpm then drasticly falls on its face, hesitating and losing power almost chocking like, does any one have any insite?
Old Nov 2, 2009 | 05:21 PM
ghost6303's Avatar
thubs up for using search and finding this thread-
but big *** thumbs down for not including any details about the car.
Old Nov 2, 2009 | 06:03 PM
carbonOX's Avatar
Have you upgraded your fuel pump to a high flow that supports more hp? Your filter might be choking your fuel supply also. Have you upgraded your filter to a high flow? What about your fuel rail and injectors?
Old Nov 2, 2009 | 06:13 PM
ImTheDevil's Avatar
Pump upgrade, I don't believe, should be needed. How about a new fuel filter? And are the plugs gapped right? Stock gap isn't gonna cut it (if you haven't gapped them down). The extra boost will be blowing the spark out.
Old Nov 2, 2009 | 06:26 PM
airguard350's Avatar
Tech Guru
^ x2 High boost cars are completely different animals.
Old Nov 2, 2009 | 06:34 PM
ghost6303's Avatar
this thread is 4 months old, the OP never even came back to respond. the guy who asked the question today probably has a stock car, but gave no information whatsoever, so he needs to come back and do that before people take more wild guesses.
Old Nov 2, 2009 | 07:01 PM
ImTheDevil's Avatar
True enough - instead of the "kiss the rings bitch" sig, it'd be a LOT more useful to have year, engine, trans, drivetrain listed.
