Help ignition.!!
Hello guys iam new at this forum and ive been trying to see where i can get help buying a new ignition? Mine broke i cant even stick the key in so i guess i need a new one wit a new key....any help would be helpfull or a link. iTS A 1996 AUDI A4 QUATTRO
Thanks |
junk yards are always a great place to start... or try www.ecstuning.com or www.purems.com
Originally Posted by CL AUDI EOUS
(Post 971425)
there is another site you can check, but unfortunately i cannot think of it right now... sorry man!
(Post 971444)
The problem with a junkyard lock barrel is that you need the key to get the barrel to work! Additionally, it won't match your exterior lock barrels.
It sucks, but you're going to end up at the dealer ordering a new ignition barrel. It's expensive, but it's often the only option. If you want a cheap, temporary fix, unplug the ignition switch harness. Buy a new ignition switch electrical component and plug it in (I think it's like $30 bucks or so). It can be operated via a screw driver. |
you can also check with www.shokan.com. If you give them the info they need they may be able to match the ignition to your existing key. I am going through this right now.
i have a ignition with a key for it plz let me know if you still need it
