help installing short shifter?
I'm going to install an off-brand b&m shifter (which was recommended to me on this very forum) and the B&m instructions say that some cars may need the entire center console to be removed. I need to know if that applies to my car and how to go about removing the console.
The instructions also tell me I need to lubricate certain parts of the shifter before installation. what should I lube with? I'm lost as to whether it means WD40 or more industrial grease. I may have more questions as time progresses, and I am hoping to install this before this weekend. For the record, here is the shifter I bought (mine did not come with a knob and some of those parts) AUDI A4 96-03 S4 00 01 SHORT THROW SHIFTER+S SHIFT KNOB | eBay Lastly, if you bought a shift knob online that you particularly like, please share. My (stock) shift knob is too wide, and it will bother me with a short shifter, im sure. |
Here..
Found this for you: JHM Short Shifter Install B5 A4 Part 1 - YouTube
and if you search hard enough on the inter-webs, you will find a written tutorial as well. The video seems pretty good.. Hope this helps you out.. |
I've installed this shifter on a 97 2.8 with push-down reverse, and a 2001.5 1.8T without push-down reverse, and didn't remove the console for either one. It's absolutely possible to do it that way.
If you have big hands or not a lot of patience, you might think about it, just because it'll open up some more space for ya, but it definitely isn't necessary. Don't use WD-40 to lube the pieces, it isn't designed for that. Use white lithium grease |
| All times are GMT -4. The time now is 05:32 AM. |
