Help Major cluster problem!
Old Sep 1, 2008 | 01:04 PM
a4audikid's Avatar
Default Help Major cluster problem!
Well I have 99.5 audi A4 2.8 FWD, I have a seroius problem with my gauge cluster, somtimes am driving & the RPM needle just drops to zero, the ABS Light comes ON, & the Brake & Oil pressure Light comes on blinking! The car runs perfectly fine when this happens, Help!!!!
Also somtimes instead the ABS Light stays ON & the brake Light Blinks!
Dont know whats wrong with my car, Dont know if its a eletrical problem, or a audi recall?
It started happening after i put my HIDs ON
HELP!!!!
Old Sep 1, 2008 | 03:02 PM
onepoint8tee's Avatar
Check for fault codes before blaming just the cluster. Could be a mixture of problems including a bad ABS control module and messed up cluster itself.
Old Sep 1, 2008 | 03:24 PM
cantdrive55's Avatar
If it started after the HID install maybe a bad ground somewhere?
Old Sep 1, 2008 | 04:08 PM
Maybe check for fault codes first?
Old Sep 1, 2008 | 04:12 PM
Audi_Skydiver's Avatar
+1 to fault codes.
Josh
Old Nov 6, 2008 | 10:12 PM
QuattroChucko's Avatar
sounds like a failing speed sensor
i know i know....reviving the dead and whatnot
Old Jul 27, 2012 | 10:56 PM
v8_ranch's Avatar
did you ever find a cause to this. I have the exact same symptoms in my 98, but it seems permanent, in that the condition is always present, yet the car runs great.
A2dak
Jan 6, 2010 11:08 AM
exequiel3k
Sep 1, 2009 01:26 AM
THEPARTSMAN10
Aug 4, 2008 11:41 AM
a42point8awd
Oct 25, 2007 05:16 PM
A4nicator
Feb 25, 2007 12:42 AM
