help is needed!!!
Old May 2, 2008 | 12:24 AM
theboss's Avatar
Default help is needed!!!
yesturday i bought a 1997 audi a4 1.8t quattro. it grinds and wont go in second while accelerating. but i can downshift and with the clutch in put it into second. third is also starting to grind very lightly. would draining the transmission fluid and putting new stuff in make a difference? what could be wrong with the car?
Old May 2, 2008 | 01:07 AM
SAudi's Avatar
Default RE: help is needed!!!
it may help try putting in gm synchromesh, this defiently sounds like a synchro problem. if the fluid dosent work sorry mate but your looking at a tranny rebuild
Old May 2, 2008 | 01:51 AM
01AudiA4's Avatar
Yeah try changing the fluids. Unfortuantly Syncrhros arn't that expenisve but labor is out the ***.
Old May 3, 2008 | 01:52 AM
theboss's Avatar
according to the original owner it just started about two weeks ago. the transmission fluid was never changed. do you thing changing it would help it. what are the symptoms of a blown synchro
Old May 3, 2008 | 02:53 AM
NLT1.8T's Avatar
pull the gear box out and rebuild it. sounds likewasted bearings as well pay close att. to case.
Old May 3, 2008 | 12:51 PM
theboss's Avatar
you mean just pull out the transmission.
desertsnake1991
Aug 28, 2012 11:07 AM
thenjd
Jan 23, 2008 04:00 AM
raffysaudi
Feb 5, 2007 06:44 PM
GregaXX
Feb 3, 2007 09:37 PM
poloblue22
Aug 3, 2005 11:10 PM
