help wanted!
Lots of issues and questions.
1996 audi a4 2.8 v6 12 valve. B5. Manual. Recent problems: 5th gear went out won't go into 5th, 1st through 4th work fine. Speedometer and odometer just went out. Cars idle isnt solid bogs down occasionally Steering wines in sharp slow turns. Any help would be much appreciated |
Originally Posted by needswork
(Post 1484932)
1996 audi a4 2.8 v6 12 valve. B5. Manual. Recent problems: 5th gear went out won't go into 5th, 1st through 4th work fine. Speedometer and odometer just went out. Cars idle isnt solid bogs down occasionally Steering wines in sharp slow turns. Any help would be much appreciated Did you check your kicker panel fuses? Have you taken the dash off recently? Idle, Check your spark plugs, and maybe your o2 sensors. I'm having a similar problem there. Steering whining, check your rack and pinion boots, look for PS fluid, it's possible the seal broke, and you are leaking. Check your PS connections on the rack, cooler line, pump and fluid level. Buy a manual, it'll help with any repairs if you haven't got one already. |
