here are some codes.... need help
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 35-10 - - - Intermittent 16806 - Main Catalyst; Bank 1: Efficiency Below Threshold P0422 - 35-10 - - - Intermittent 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-10 - - - Intermittent 16685 - Cylinder 1: Misfire Detected P0301 - 35-10 - - - Intermittent 16687 - Cylinder 3: Misfire Detected P0303 - 35-10 - - - Intermittent 16688 - Cylinder 4: Misfire Detected P0304 - 35-10 - - - Intermittent 16524 - Oxygen (Lambda) Sensor B1 S2: No Activity P0140 - 35-10 - - - Intermittent |
You need to replace all of your coil packs, your catalytic converter, and both of the 02 sensors attached to your exhaust system.
Originally Posted by stac104
(Post 1096692)
What year and engine is the car? |
