high mileage
ok so i have a 96 b5 a4 and it just hit 98000 miles. and a In1 signal turns on when i turn the car on. i kno it means i have to get the car inspected but what is the usual maintenance at this mileage?
5,000 miles
Engine Oil: Change Oil Engine Oil Filter : Replace the engine oil filter Wheels: Rotate front to rear Fluid Levels: check all fluid levels Automatic Shift Lock: check operation ( Automatic transmission only) Brake System: check pad thickness and brake fluid level Manual Transmission: check gearshift and clutch for proper operation 10,000 Miles Engine Oil: Change Oil Engine Oil Filter : Replace the engine oil filter Cooling System: check coolant level Exhaust System: check for damage and leaks Engine On-Board Diagnostic: check trouble code memory Doors: lubricate hinges Battery: check electrolyte level Windshield wiper and washer: check fluid level, add fluid if necessary Automatic Shift Lock: check operation ( Automatic transmission only) Manual Transmission: check gearshift and clutch for proper operation Tires and spare wheel: check for wear and damage, adjust pressure Brake System: check for damage and leaks, check thickness of pads and fluid level Drive Shafts: check the boots Road test: check braking, kick down operation ( automatic transmission only), electrical, Heating and ventilation systems, air conditioning, and power accessories Lights: check the lights 20,000 Miles Engine Oil: Change Oil Engine Oil Filter : Replace the engine oil filter Engine: check for leaks Cooling System: check coolant level Exhaust System: check for damage and leaks Engine On-Board Diagnostic: check trouble code memory Doors: lubricate hinges Battery: check electrolyte level Windshield wiper and washer: check fluid level, add fluid if necessary Automatic Shift Lock: check operation ( Automatic transmission only) Manual Transmission: check gearshift and clutch for proper operation Tires and spare wheel: check for wear and damage, adjust pressure Brake System: check for damage and leaks, check thickness of pads and fluid level Drive Shafts: check the boots Lights: check the lights Front Axle: check dust seals, ball joints, and tie rods, and tie rod ends Automatic Transmission : check for leaks Manual Transmission : check for leaks Manual Transmission Final Drive: check fluid level Dust and Pollen Filter: replace filter Headlights: inspect headlights Sliding Roof : clean guide rails, and lubricate 30,000 Miles Engine Oil: Change Oil Engine Oil Filter : Replace the engine oil filter Cooling System: check coolant level Exhaust System: check for damage and leaks Engine On-Board Diagnostic: check trouble code memory Doors: lubricate hinges Battery: check electrolyte level Windshield wiper and washer: check fluid level, add fluid if necessary Automatic Shift Lock: check operation ( Automatic transmission only) Manual Transmission: check gearshift and clutch for proper operation Tires and spare wheel: check for wear and damage, adjust pressure Brake System: check for damage and leaks, check thickness of pads and fluid level Drive Shafts: check the boots Road test: check braking, kick down operation ( automatic transmission only), electrical, Heating and ventilation systems, air conditioning, and power accessories Lights: check the lights 40,000 Miles Engine Oil: Change Oil Engine Oil Filter : Replace the engine oil filter Engine: check for leaks Cooling System: check coolant level Exhaust System: check for damage and leaks Engine On-Board Diagnostic: check trouble code memory Doors: lubricate hinges Battery: check electrolyte level Windshield wiper and washer: check fluid level, add fluid if necessary Automatic Shift Lock: check operation ( Automatic transmission only) Manual Transmission: check gearshift and clutch for proper operation Tires and spare wheel: check for wear and damage, adjust pressure Brake System: check for damage and leaks, check thickness of pads and fluid level Drive Shafts: check the boots Lights: check the lights Front Axle: check dust seals, ball joints, and tie rods, and tie rod ends Automatic Transmission : check for leaks Manual Transmission : check for leaks Manual Transmission Final Drive: check fluid level Power Steering Fluid: check fluid level Dust and Pollen Filter: replace filter Headlights: inspect headlights Sliding Roof : clean guide rails, and lubricate Air Cleaner: replace filter element Spark Plugs: replace the plugs 60,000 Miles Engine Oil: Change Oil Engine Oil Filter : Replace the engine oil filter Engine: check for leaks Cooling System: check coolant level Exhaust System: check for damage and leaks Engine On-Board Diagnostic: check trouble code memory Doors: lubricate hinges Battery: check electrolyte level Windshield wiper and washer: check fluid level, add fluid if necessary Automatic Shift Lock: check operation ( Automatic transmission only) Manual Transmission: check gearshift and clutch for proper operation Tires and spare wheel: check for wear and damage, adjust pressure Brake System: check for damage and leaks, check thickness of pads and fluid level Drive Shafts: check the boots Lights: check the lights Front Axle: check dust seals, ball joints, and tie rods, and tie rod ends Automatic Transmission : check for leaks Manual Transmission : check for leaks Manual Transmission Final Drive: check fluid level Dust and Pollen Filter: replace filter Headlights: inspect headlights Sliding Roof : clean guide rails, and lubricate 80,000 Miles Engine Oil: Change Oil Engine Oil Filter : Replace the engine oil filter Engine: check for leaks Cooling System: check coolant level Exhaust System: check for damage and leaks Engine On-Board Diagnostic: check trouble code memory Doors: lubricate hinges Battery: check electrolyte level Windshield wiper and washer: check fluid level, add fluid if necessary Automatic Shift Lock: check operation ( Automatic transmission only) Manual Transmission: check gearshift and clutch for proper operation Tires and spare wheel: check for wear and damage, adjust pressure Brake System: check for damage and leaks, check thickness of pads and fluid level Drive Shafts: check the boots Lights: check the lights Front Axle: check dust seals, ball joints, and tie rods, and tie rod ends Automatic Transmission : check for leaks Manual Transmission : check for leaks Manual Transmission Final Drive: check fluid level Power Steering Fluid: check fluid level Dust and Pollen Filter: replace filter Headlights: inspect headlights Sliding Roof : clean guide rails, and lubricate Air Cleaner: replace filter element Spark Plugs: replace the plugs 100,000 Miles Engine Oil: Change Oil Engine Oil Filter : Replace the engine oil filter Engine: check for leaks Cooling System: check coolant level Exhaust System: check for damage and leaks Engine On-Board Diagnostic: check trouble code memory Doors: lubricate hinges Battery: check electrolyte level Windshield wiper and washer: check fluid level, add fluid if necessary Automatic Shift Lock: check operation ( Automatic transmission only) Manual Transmission: check gearshift and clutch for proper operation Tires and spare wheel: check for wear and damage, adjust pressure Brake System: check for damage and leaks, check thickness of pads and fluid level Drive Shafts: check the boots Lights: check the lights Front Axle: check dust seals, ball joints, and tie rods, and tie rod ends Automatic Transmission : check for leaks Manual Transmission : check for leaks Manual Transmission Final Drive: check fluid level Dust and Pollen Filter: replace filter Headlights: inspect headlights Sliding Roof : clean guide rails, and lubricate 120,000 Miles Engine Oil: Change Oil Engine Oil Filter : Replace the engine oil filter Engine: check for leaks Cooling System: check coolant level Exhaust System: check for damage and leaks Engine On-Board Diagnostic: check trouble code memory Doors: lubricate hinges Battery: check electrolyte level Windshield wiper and washer: check fluid level, add fluid if necessary Automatic Shift Lock: check operation ( Automatic transmission only) Manual Transmission: check gearshift and clutch for proper operation Tires and spare wheel: check for wear and damage, adjust pressure Brake System: check for damage and leaks, check thickness of pads and fluid level Drive Shafts: check the boots Lights: check the lights Front Axle: check dust seals, ball joints, and tie rods, and tie rod ends Automatic Transmission : check for leaks Manual Transmission : check for leaks Manual Transmission Final Drive: check fluid level Power Steering Fluid: check fluid level Dust and Pollen Filter: replace filter Headlights: inspect headlights Sliding Roof : clean guide rails, and lubricate Air Cleaner: replace filter element Spark Plugs: replace the plugs 140,000 Miles Engine Oil: Change Oil Engine Oil Filter : Replace the engine oil filter Engine: check for leaks Cooling System: check coolant level Exhaust System: check for damage and leaks Engine On-Board Diagnostic: check trouble code memory Doors: lubricate hinges Battery: check electrolyte level Windshield wiper and washer: check fluid level, add fluid if necessary Automatic Shift Lock: check operation ( Automatic transmission only) Manual Transmission: check gearshift and clutch for proper operation Tires and spare wheel: check for wear and damage, adjust pressure Brake System: check for damage and leaks, check thickness of pads and fluid level Drive Shafts: check the boots Lights: check the lights Front Axle: check dust seals, ball joints, and tie rods, and tie rod ends Automatic Transmission : check for leaks Manual Transmission : check for leaks Manual Transmission Final Drive: check fluid level Dust and Pollen Filter: replace filter Headlights: inspect headlights Sliding Roof : clean guide rails, and lubricate Josh |
thnx and how do i get rid of the In1 code?
search and ye shall find.......has been covered in the forum a couple of times.
My car is at 162 and change... What do you do for an inspection then? Standard oil change etc. etc.?
