High Reving between Gear Changes
Old Feb 6, 2008 | 05:32 PM
vwroyd's Avatar
Default High Reving between Gear Changes
Hi, i have an A41.8T Sport 2001 and when i drive it hard the revs stay high between gear changes, does anyone know what the problem may be?
Any help would be much appreciated.
Thanks Chris
Old Feb 8, 2008 | 08:05 PM
TDRILL's Avatar
Default RE: High Reving between Gear Changes
manual? What do you mean stay high? The A4 doesn't exactly shift quickly. The tach is a bit slow to come down in general so during spirited driving you will see that the tach often just sits there between shifts and doesn't move until you are re-engaging the clutch. This would be normal if this is what you are talking about so you need to be more specific if its not. Way to get a more responsive tach is a light weight fly wheel (LWFW) when you replace the clutch.
Old Feb 15, 2008 | 05:31 PM
vwroyd's Avatar
Thanks TDRILL, i think what you are saying isright.
Cheers
Old Feb 15, 2008 | 06:57 PM
FASTER's Avatar
Tech Slut
ORIGINAL: TDRILL
your tach will not be "more responsive"... the motror can spin up and down faster due to the less restriction through weight.
Old Jun 7, 2008 | 04:42 AM
Matt_Iliketurbopull's Avatar
hi mate
I had a quick look at your post, it maybe your throttle body, or the MAF I can't remember what the mechanic thought it might be, but I noticed my car tends to have the revs linger between gear changes.
Old Jun 8, 2008 | 12:10 AM
oettinger1919's Avatar
SoCal Crew Member
let off the gas before you put the clutch in
BBS-Line
B7 Models
Jul 25, 2012 11:37 AM
vwroyd
Feb 6, 2008 05:32 PM
sweeds4
Dec 1, 2007 06:14 PM
nicka
Jul 16, 2007 09:03 AM
99AudiA4q
Nov 10, 2004 07:06 PM
