how much to for a new head gasket installed
Old 03-15-2011, 05:50 PM
austindgarner's Avatar
Default how much to for a new head gasket installed
I think my head gasket is going out, how much would it be to replace it
Old 03-15-2011, 05:53 PM
ImTheDevil's Avatar
Depends on where you go. At a dealer it's going to cost a fortune. An indie euro shop will be less. Find a forum member who can do it for you and it'll likely be quite a bit less.
Old 03-15-2011, 06:00 PM
how much is a fortune and how much is alot less
Old 03-15-2011, 06:11 PM
ImTheDevil's Avatar
It'll depend on where you are but I'm betting a dealer will get $2000+ easy for parts and labor.
Old 03-15-2011, 06:21 PM
bradtyler02's Avatar
100 bucks for parts... DIY for free.
Old 03-15-2011, 06:44 PM
ImTheDevil's Avatar
More than that - gotta get new head and vc gaskets, new head hardware, and the timing service should be done as well rather than reuse the old stuff and have to duplicate the labor.
I should revise my prior post - with these parts, a dealer is probably closer to $3000. Auditech79 could probably tell us for sure based on his experience.
Old 03-15-2011, 09:59 PM
Msnickbroderick's Avatar
Actual WIZARD
Sure its not an oil cooler? What makes you think the headgasket is on its way out?
Old 03-16-2011, 11:08 AM
krazzz's Avatar
I just ordered the Head gasket kit and timing kit from ECS. You definitely want to do these jobs together because it isn't that much more work. The timing kit was $284 and the head gaskets were $120 per side and you need new bolts for $59. For me was $583 to do the head and timing.
Old 03-16-2011, 05:44 PM
i found a local mechanic thats doing the job for 650 parts and labor, he said it was the head gasket and that ive been running on 3 cylider bc coolant was puddled up in cylinder 2 and it wasing getting a spark. He really seams to know his stuff and does it out of a shop behind his house. charges 45 an hour. I think i got lucky on this on. He was refered to my by a lamas audi driver that i know.
Old 03-16-2011, 05:58 PM
sounds good, but the TB should be done as well, like the others have mentioned.
Quick Reply: how much to for a new head gasket installed
