AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   how to remove quattro, rear driveshaft at rear diff. (https://www.audiforums.com/forum/b5-models-69/how-remove-quattro-rear-driveshaft-rear-diff-186882/)
moneyfresh Aug 31, 2012 11:44 PM
not sure why, removed the bolts did a little hammering still not movement, letting the penetrate to eat the rust overnight, any ideas? front at tranny came out nice and easy.
jonbonesjones Sep 1, 2012 07:55 AM
You pop the center carrier off also? Should just be able to persuade it with a metal hammer.
moneyfresh Sep 1, 2012 11:05 AM
yeah driveshaft support is removed also, thats the reason why im doing this. replace that worn out original one.
Tweaked Sep 1, 2012 08:31 PM
Don't whack it with a metal hammer, you can damage the joint. It just takes some time to walk it off using a deadblow. It's a large joint, and often gets stuck.
b5blazing Sep 2, 2012 07:02 AM
Laying under car put one hand on drive shaft and one hand on diff snout. Shake vigorously should separate. Metal hammer no dead blow or rubber malet yes.
I know mine hit me in the face when I popped it out last time.
moneyfresh Sep 3, 2012 04:53 PM
successfully removed it, just let the wd 40 rust penatrint to work, was just stuck and sezsed replaced the driveshaft support fixed that vibration when under a load, just wondering if theres a proper way to align the driveshaft i still have a little vibration in first, when doing 4g launchs
