how to remove/replace shifter boot in a 1999?
Old Aug 16, 2010 | 12:28 AM
alexmurphy's Avatar
Default how to remove/replace shifter boot in a 1999?
So I have a 1999 A4 and the shifter boot is getting to look a tad old and used, so I want to replace it with another one.
First off, I am assuming that any basic boot will work with this car. If it won't, stop me there.
Anyway, I found that the shifter **** just unscrews easily enough, but I don't know how to get the boot off. I am assuming that I have to pull off a faceplate or something and I don't want to do it without knowing exactly what needs to happen. So does anyone know how to do this? (if you can find a how-to video (i couldn't), that would be great!)
Old Aug 16, 2010 | 01:03 AM
FASTER's Avatar
Tech Slut
you just kind of pop it out... Put your fingers in between the rim of it and the console and basically pull it out.
Old Aug 16, 2010 | 08:38 AM
CCA4's Avatar
Yeah there's no real trick to it. If you wedge your fingers in under where the leather boot meets the plastic part of the center console, you should feel a little plastic frame underneath the leather. If you shove that forward and lift up, you should be able to pop it right out.
Old Aug 16, 2010 | 11:12 PM
alexmurphy's Avatar
well that sounds simple enough...what about getting it back on? just tuck it in and snap it into place?
Old Aug 17, 2010 | 01:54 AM
FASTER's Avatar
Tech Slut
just pop it back in... you'll see when you look at it, super easy
alan93
Dec 27, 2011 10:55 AM
chickeneater
Dec 7, 2010 12:41 AM
bkane
Jul 23, 2009 12:28 PM
area51zc
Jun 14, 2009 01:10 PM
moeron7
Feb 5, 2007 11:01 AM
