How to wire a boost gauge?
Old May 6, 2010 | 10:54 PM
jhanson25's Avatar
Default How to wire a boost gauge?
Hello all! I just got a new Glow Gauge Vac/boost gauge today and have everything hooked up and running except for the wiring to light it. It mentions in the instructions to run to a 12v constant and also a 12v ignition source for the wires. I have looked and looked online and don't know which wires to tap into. Can anyboy give me any ideas? Thanks so much!!!
Old May 6, 2010 | 10:57 PM
joenelson7687's Avatar
I did mine to the headlight fuse. Everytime I turn my headlights/running lights on, they gauge light comes on. There is a bolt at the top the the fuse panel that gave me a good ground too. This way has worked for me with no problems. I'm sure there are other ways too.
Old May 6, 2010 | 11:22 PM
hiwords's Avatar
do what joe said or you could wire it to the yellow post behind the kneebolster. that is your ignition post and will provide you with power whenever your key is in the "ON" position
Old Jun 1, 2010 | 05:10 PM
rb12's Avatar
Default Wiring
I've looked and looked and wandering if somebody could put a pic of were to wire your boost gauge to get power?
Old Jun 1, 2010 | 10:39 PM
^^^To the fuses mentioned above in the fuse panel. Its right there on the side of your dash when you open your driver's door.
A4driver17
Dec 23, 2011 03:59 PM
rplets15
Apr 21, 2009 05:33 PM
Soley4pres
Jan 31, 2007 04:08 AM
ravenTT
Dec 9, 2006 12:25 AM
s4me
May 18, 2005 08:39 PM
