Humming noise from the rear
Old Feb 16, 2008 | 12:25 PM
garimella's Avatar
Default Humming noise from the rear
Changed the fuel filter on my car after going through the earlier posts on the humming noise from the rear. Found that the fuel filter was neva replaced coz the older one had the orange sticker on it. The noise still wouldn't go. I think something is wrong with the fuel pump tooo...So planning to change it. I have a '96 A4 quattro 2.8l, 100k miles. Will this fit my car.
http://cgi.ebay.com/ebaymotors/VW-Au...em120222664401
Thanks
Old Feb 16, 2008 | 12:54 PM
garimella's Avatar
Default RE: Humming noise from the rear
any body pleaseeeeeeeeeee
Old Feb 16, 2008 | 02:02 PM
hiwords's Avatar
call up audi and ask them for a part number check
Old Feb 16, 2008 | 02:38 PM
garimella's Avatar
hey thanks.....shud i call up the audi dealer or audiUSA????...weekend so wondering what to do.....
Old Feb 16, 2008 | 03:04 PM
MrFlippant's Avatar
This is just a punt, but is there any chance that this humming noise increases/decreases along with the speed of the car?
Old Feb 16, 2008 | 05:34 PM
garimella's Avatar
ya..i have been observing it for sometime now......it actually is prominent at around 40-45 mph. and then increase a bit and stays the same for the rest of higher speeds.......
Old Feb 17, 2008 | 03:33 AM
formula's Avatar
hey man, i think the problem may be your wheel bearings. I noticed a humming noise whenever i reached ~40mph aswell. Same exact symptoms. check it out
Old Feb 17, 2008 | 03:34 PM
skills@eurocarsplus's Avatar
x2 on a wheel bearing (or any other rear end bearing) if you hear a fuel pump at that speed, it has to be mounted in your cup holder
Old Feb 17, 2008 | 11:07 PM
david9999's Avatar
If the noise gets louder or softer as you slightly change directions it is most likely wheel bearing. You may want to also check the gear oil in the rear differential assuming you have quattro to make sure that isn't the problem.
Old Feb 18, 2008 | 01:15 AM
garimella's Avatar
going by what u just said....it's def not the wheel bearing then. The noise is uniform and well looks like i will have to look at the floowing on this issue
Fuel pump
rear differential fluid.
anything else????
