MBC install question
Old 06-04-2013, 10:06 AM
Pbcrazy's Avatar
Default MBC install question
So basically my chip is set for 12.5psi, but yet my car spikes at 14-15psi and starts bucking like crazy, it runs up to 13psi perfectly. So I want to install a mbc to control the boost so it won't go over 13psi, I have read I should run it in parallel to the n75 valve basically by just cutting the tube running from the n75 into 2 and just install the mbc there. Here's the problem, this accounts for the bottom nipple and a side nipple. My mbc (forge) has a bottom nipple and 2 side nipples, do I just plug one side nipple and just install it like I mentioned?
Old 06-04-2013, 10:57 AM
MetalMan's Avatar
Moderator
Have a read on this page:
BoostValve VW Audi 1.8T Over Boost Correction kit Explained
It's kinda long, if you skim you can get the jist of it.
Sounds like you're thinking that you are getting "overboost". My FrankenTurbo setup overboosts pretty badly, on the order of 25+psi (the highest my gauge will read) when the tune is set for 20-22psi. So I've got a BoostValve MBC in parallel with the N75, and set so boost hits ~21psi max and holds there.
I've read around, and for overboost or high boost spikes (like what you're describing) the Forge unit doesn't really react fast enough to be very effective.
Audi VW
I think one of the Forge's nipples is the bleeder port, which would connect to your intake I believe.
Old 06-04-2013, 01:11 PM
CCA4's Avatar
I have a three port forge MBC that you can have if you want it. I used it in conjunction with the "diode" mod before I got a proper tune. You're correct, the third/bottom port is the bleed, and it can either be plumbed back into the intake or just bled off to atmosphere without too much trouble. If I were you, I'd go with a BoostValve ball/spring type instead of the Forge bleeder type. Much better for this application
Old 06-04-2013, 02:57 PM
Pbcrazy's Avatar
I already have the forge, thanks though. Ill just return it and get the boost valve, am I correct in the installation aspect? Cutting the line going from the n75 and putting the boost valve so the side nipple is towards the n75 and the bottom is away?
Old 06-04-2013, 03:06 PM
Pbcrazy's Avatar
Nevermind, just realized the over boost correction kit from boostvalve comes with everything and (hopefully) instructions
Old 06-04-2013, 04:35 PM
Pbcrazy's Avatar
Can somebody explain this diagram they use as instructions? No title
I wish they would label the parts...
Old 06-05-2013, 04:56 AM
redline380's Avatar
Legal Moderator
what do you need to know about the diagram? i added some descriptions.
1.8_Turbo
05-23-2012 06:37 PM
cantdrive55
07-26-2008 09:59 PM
mbertoli
01-16-2008 02:24 PM
mikejda
04-07-2007 09:26 PM
krue92
07-26-2005 06:56 PM
Quick Reply: MBC install question
