I made a mistake, now i cant open my passengers door
Old Jun 21, 2012 | 01:32 PM
nyisles8388's Avatar
Default I made a mistake, now i cant open my passengers door
I was taking off my plastic door handles, removed the door panel and put it back on, but i made a mistake forgot to pull the door look up through the hole before i fastned the door panel back on and closed the door, now i cant open the door at all to gett to the screws to remove the panel and pull the look through the hole. What do i do
Old Jun 21, 2012 | 02:44 PM
CCA4's Avatar
hmm, that's a good one. You prolly won't be able to force the door open from the inside because the action of pulling the handle also pushes the locking **** up. If the **** won't go up, the handle won't pull out and the door won't open. Seems to me like you're gonna have to break something to get it...
Old Jun 21, 2012 | 04:09 PM
airguard350's Avatar
Tech Guru
Try and see if you can pull just the bezel for the door handle out. If you can get the bezel out, you might be able to reach a hanger, your fingers, etc. in and put the lock **** back in it's place.
Old Jun 21, 2012 | 06:05 PM
This worked, and nothing broke, phew
thanks
Old Jun 21, 2012 | 06:07 PM
mtroxel's Avatar
If it's just the door lock rod, the one that sticks up through the door panel, you shouldn't need it. If your power locks work you should be able to unlock it that way. Maybe I understood this all wrong.
alh3010
Apr 11, 2013 01:18 PM
rclive
Jul 13, 2011 07:35 PM
Pablo_Ottawa
Aug 8, 2008 05:44 PM
cosmec
Mar 31, 2005 06:38 PM
