I want these springs to work...
Old Mar 16, 2008 | 09:45 AM
sineo's Avatar
Default I want these springs to work...
http://houston.craigslist.org/pts/573533093.html
Will they work for my 2.8 Avant? Would the added weight just make the car a bit lower...or worse?s
Old Mar 16, 2008 | 09:54 AM
NewJ_A4's Avatar
Member
Default RE: I want these to work...
Sieno its 75 bucks buy em n try em sweety. all else fails put em back on CL for $100 n make that buck back.
Old Mar 16, 2008 | 10:59 AM
turbo kraut's Avatar
Tech Guru
or on here
but as long as your pearches are the same, the only real "problem" if they fit you will have is maybe a lil crappier ride and sit lower due to heavier engine
Old Mar 16, 2008 | 11:39 AM
ImTheDevil's Avatar
That was my understanding of the difference between 1.8T and 2.8 springs - the fronts at least are heavier duty for the 2.8 due to the heavier engine. The rest should be the same.
Old Mar 16, 2008 | 11:46 AM
01afour's Avatar
deff. worth the $75 to give it a shot, but its sounds like wut most ppl said the front is probably gunna be lower, but then again the added weight in the back may level it out anyway.
Old Mar 16, 2008 | 11:50 AM
hiwords's Avatar
just try to avoid pot holes
Old Mar 16, 2008 | 12:11 PM
sineo's Avatar
ORIGINAL: hiwords
Sound advice as always.
Thanks guys.
ChuteBoxe360
Apr 12, 2013 06:41 PM
AlexB27
Oct 4, 2012 07:53 PM
88notchblown
Sep 27, 2009 01:34 PM
Prizmatik
Mar 1, 2009 11:28 PM
krnaudi
Mar 30, 2007 04:50 AM
