intercooler core quality, size and myths
Old Jan 9, 2008 | 03:18 AM
Matt_Iliketurbopull's Avatar
Default RE: godspeed core quality vs racetec
the links are good, Ive found autospeed to be a good source.
Old Jan 9, 2008 | 09:25 AM
chaos92287's Avatar
ORIGINAL: Matt_Iliketurbopull
yes that is also a very good core. and 034 sells that piping, it'll definitely hold up to the power
is the garrett bar and plate? - YES!!! My favorite
where is the precision core, is it a kit?
precision core- http://www.nolimitmotorsport.com/prod/AS1021
i dont think they make a kit to fit the b5 a4's so you'll have to get piping seperate
Old Jan 9, 2008 | 09:42 AM
chaos92287's Avatar
this is the difference between ebay and quality cores
Old Jan 9, 2008 | 11:01 AM
cincyTT's Avatar
I'm make believe
The godspeed is a very low dense core where the garrett/precision (they both use garrett cores) are very high dense cores. The precison 350hp core will work for you. Its about $300 and will keep the temps a few deg above abient as were the godspeed core will keep it probably closer to 20-30* higher, depending on size.
Old Jan 9, 2008 | 03:15 PM
I didn't know the 3.5 inch would fit, I guess its only 6 inches high and doesnt interfere with the bumper support?
Old Jan 9, 2008 | 03:19 PM
cincyTT's Avatar
I'm make believe
it shouldnt. But if you want to get a 3" core, you can get the garrett 400hp core from atp but its more.
Old Jan 9, 2008 | 03:47 PM
chaos92287's Avatar
on a stock a4 bumper it would require some trimming
Old Jan 9, 2008 | 03:49 PM
  #18
thank you,
I'll probly get this http://forums.motivemag.com/zerothread?id=3551132so don't have to think about custom piping, hacking the bumper should be enough pain. Plus the moulded hoses look very cool-OEM like.
Old Jan 9, 2008 | 03:51 PM
  #19
cincyTT's Avatar
I'm make believe
That would be the best one to go with. Its a garrett core and should fit well
Old Jan 9, 2008 | 07:31 PM
  #20
sean1.8t's Avatar
i have the exact same core as the one that 034 is selling. it is leaps and bounds above the AWE core as far as reducing and pretty much eliminating heat soak. i am very happy with it. it fits nicely under my stock B6 bumper(although my rebar installed. so you'll have to trim that up if you keep it on your car).
