Jumping lizard balls
Old May 10, 2013 | 05:33 PM
Expplucky's Avatar
Default Jumping lizard *****
OK so im moving this problem over to the b5 for better results.
soooo im getting misfire on the right bank on the engine, one random misfire code then 4,5,6.
i can hear debree being kicked around on that side witin the exhuast so i ordered a mig welder so i can remove it and re-weld that **** back.
my question is this tho, while i wait for the welder to get here what other things can i try,
ive already done the following:
-replaced both catalytic convertors
-Checked fuses
-changed fuel filter
-changed spark plugs and Gaped @.32
-redid timing belt
-water pump replaced
-thermostat replaced
-new belt tensioner
-new serp belt as well
-changed vavle cover gaskets
-replaced coil pack
-most of the plug wires
-did a spark test getting spark
-checked for the injector pulse (the screw driver method)
-left battery unpluged over night to reset fuel trims
-replaced maf (like 3 times)
-cleaned throtle body and entire intake manifold
-ordered the vag-com cable and got vcds
-ran seafoam through the tank
-and a little in the intake
-changed vac lines (not very well tho i did have to replace that 3way valve with some ghetto hose invention, and replace the braded hose from the vaccum res with a rubber hose)
any ideas would be great.
Old May 10, 2013 | 06:02 PM
bshusted's Avatar
What condition is your PCV system in? The hoses and valve that connect to the crank case and valve covers see intake vacuum and can cause issues.
Old May 10, 2013 | 06:21 PM
Expplucky's Avatar
its decent, i mean i replaces the old plastic hoses n ****.
Old May 10, 2013 | 09:09 PM
Mad Cow's Avatar
Could be a clogged cat on one bank, though I don't know where a welder would come in. Have you checked compression or done a leakdown test?
Completely off topic, but bshusted, I see you have aero wipers from your sig, are they B5.5 Passat wipers?
Old May 10, 2013 | 11:28 PM
bshusted's Avatar
Yup. Got the blades and arms from a partout on Vortex for ~$40 shipped. I replaced the rubber with silicone refills from PIAA and it's the best wiper setup I've ever owned. Even my wife commented that she liked them and that's really saying something.
Old May 11, 2013 | 12:03 AM
Expplucky's Avatar
but i literaly just replaced the cats!!!! 2-weeks ago....and my system is not a bolt on. its all welded.
Old May 18, 2013 | 02:06 PM
ImTheDevil's Avatar
Awhile back I mentioned that since all the fails are on bank 2, it could be a cam sensor. Did you ever look into it? Could be a failing CCT on that bank as well, allowing a cam phasing problem to occur.
Old May 18, 2013 | 04:23 PM
Expplucky's Avatar
DEVIL yes i mean i ordered one recently, i havent been able to set up my vag-com with vcds for some reason it wont recognize the interface so i cant know for sure. ill have a look at the tensioner when i get a day off work. for now im just trying to get this damn car to work with vcds.
Old May 27, 2013 | 08:09 PM
Expplucky's Avatar
ok so its for sure not the cps and vagcom just tells me the same thing my scanner did, still getting a random mis code and cyl 4,5,6 and a loud popping noise. please help its been 3 months sense ive driven this car.
colony777
Sep 9, 2010 06:22 PM
MrFlippant
Jul 16, 2009 09:06 PM
bottlecap
Feb 16, 2009 11:27 PM
