k03 vs Mild k04
Hi all.I know I've asked a similar question, but the deeper I dig the more questions arise. Breifly the turbo on my std 96 1.8t blew with the aid of some oil feed problems. Engine flushed through and new oil pump fitted now ready for replacement turbo. I intended to chip the car b4 the turbo blew, but my thinking on this has changed a little. With a std chip, around 190/200bhp on the k03, the turbo is I beleive producing somewhere in the region of 17/22 psi, and is maxed out so working Hard. As I'm replacing the turbo,I'm finding it hard to resist fitting the larger k04. Now I'm not looking to really go above the 190/200 bhp mark, to preserve as many mechanicals as poss. I've read on lots of posts that fitting the k04 requires specialised mapping larger air flow sensor, injectors and so on to get the max from it. But if I run the k04 with the boost set lower say 12/14 psi with a std k03 chip, would the k04 still be moving the same volume of air as a 20psi k03 and therefore produce the same sort of BHP without the strain on the turbo. The maths may need a tweek but is this theory practical.. Cheers to anyone in the Know. |
just doing a direct bolt on k04 wont make much of a difference from a k03. if u got the bigger injectors and k04 software your car would be right at or even above the 190/200bhp mark
already said in your other thread. Used ko3s, ko3 chip, mbc set to 20psi, done
ill sell you my k03s i just took off my car :) amazingly it has 0 shaft play, but you would still need to have it rebuilt cuz i busted the stipped nut and broke part of the stud that goes into the dp. but gpopshop.com can rebuild it for cheaper then buying a k04 ($350-400 i think).
you do not need bigger injectors and a maf with a k04, that is only if your getting the aggressive pc 16 or hammer files. there is a k04 basic file that does not need that stuff! |
to run pc 16 it is necessary to run bigger injectors a 3 bar fpr and an intercooler
exhaust is also highly recommended.... |
OK, a k03s is from a 2000 model onwards, is that correct ? Is this also known as a k03-029 ? or does anybody know the relevant part no? cheers
k03s is 2001+
Unitronics also has a KO4 file that uses injectors. honestly if you have a need for speed then the KO4 probably isn't going to do it for you anyhow, so go with whatever you can get cheapest to get you by until there's some cash for the BT kit :D
cheers, Josh |
