ko3, ko3s, and ko4-015 sizing.
Old 11-13-2008, 11:02 PM
cincyTT's Avatar
I'm make believe
Default ko3, ko3s, and ko4-015 sizing.
Since people here LOVE to talk about upgrading to a ko3s and ko4, i thought you guys would like to actually see the size differences. That, and im sick of stating the differences almost monthly
Ko3 - 97-2000
COMPRESSOR WHEEL
Inducer: 33.6mm
Exducer: 46mm
Tip height: 3.7mm
TURBINE WHEEL
Inducer: 45mm
Exducer: 38mm
Tip height: 6.8mm
Blades: 11
Ko3S - 01+
COMPRESSOR WHEEL
Inducer: 38mm
Exducer: 51mm
Tip height: 4.4mm
TURBINE WHEEL
Inducer: 45mm
Exducer: 38mm
Tip height: 6.8mm
Blades: 11
Ko4-015
COMPRESSOR WHEEL
Inducer: 35mm
Exducer: 50mm
Tip height: 3.7mm
TURBINE WHEEL
Inducer: 50mm
Exducer: 42mm
Tip height: 6.4mm
Blades: 11
As you can see and have been told, the ko3s has a larger compressor wheel than both the ko3 and ko4 along with a more effecient design. However, the ko4 has a slightly larger turbine wheel which makes it able to flow the higher power made by chipping better. The best thing to do if you really want to go this route is to buy a ko4 AND used cheap/dead ko3s and swap the compressor wheel and housing to the ko4. This should net you a few more whp and tq
Old 11-14-2008, 12:24 AM
EpicWin's Avatar
You're the mod, make it a sticky
Here's a cool sheet of what engines a K03s came on (by engine code):
http://www.qpeng.com/faqs/engine_faq...they_mean.html
Old 11-14-2008, 12:49 AM
Tweaked's Avatar
Good info. Thanks again cincyTT.
Old 11-14-2008, 12:42 PM
cincyTT's Avatar
I'm make believe
This info has now been added to the 1.8t turbo upgrade thread in the sticky above. You can also have people search for this thread if need be.
Old 11-14-2008, 02:05 PM
Jc61990's Avatar
would the inducer be the same as the inlet size?
Old 11-14-2008, 02:13 PM
cincyTT's Avatar
I'm make believe
No, the inlet can be tapered down to the inducer size. For instance, a gt30r can come with a 4" inlet but the inducer is a little more than 2"
Old 11-14-2008, 03:26 PM
TeeterTawter's Avatar
"The best thing to do if you really want to go this route is to buy a ko4 AND used cheap/dead ko3s and swap the compressor wheel and housing to the ko4. This should net you a few more whp and tq"
Isnt this what Gpopshop does with their hybrid Ko4s?
Old 11-14-2008, 03:54 PM
cincyTT's Avatar
I'm make believe
Thats what i was thinking. Havent gone searching if that was the case or not. Should be cheaper and make slightly better numbers than a new ko4-015
Old 11-14-2008, 03:58 PM
http://www.gpopshop.com/kkkturbos.html thats there info, i don't think they do
A4speed's Avatar
thanks for the good info!
Quick Reply: ko3, ko3s, and ko4-015 sizing.
