ko4 with revo software?
Old Jan 1, 2008 | 11:12 PM
Mya4T's Avatar
Default ko4 with revo software?
buying an a4 with revo stage 2 software. is that compatiable with the ko4 or what turbos will it work with
Old Jan 1, 2008 | 11:22 PM
cincyTT's Avatar
I'm make believe
Default RE: ko4 with revo software?
From my knowledge, revo stg 1 and 2 are both ko3 sw and stg3 was either 380/440/550cc files. You can do a ko4 on stg2 but since you cant use lemmiwinks/unisettings it would be hard to get fueling right unless you get a wbo2 and tune with a adj fpr which is less than ideal
Old Jan 1, 2008 | 11:30 PM
Mya4T's Avatar
so then what do you suggest i do?
Old Jan 1, 2008 | 11:32 PM
cincyTT's Avatar
I'm make believe
what are you trying to do? Are you buying a new car or upgrading turbos? Your first post is kind of misleading... to me atleast
Old Jan 1, 2008 | 11:33 PM
hiwords's Avatar
buy the a4, get a stock ecu, chip it with apr or giac. least that's what i would do if i wanted that car realy bad. otherwise find a different car.
Old Jan 1, 2008 | 11:35 PM
Mya4T's Avatar
alright buying a 01 with test pipe 2.5 inch borla exhaust fmic intake evo ms dv and stage 2 revo tuning. in the futrue i want to go k04 maybe larger but lets just say ko4 for now. cani put a ko4 on with that software or do i ahve to go giac what can i do
Old Jan 1, 2008 | 11:38 PM
cincyTT's Avatar
I'm make believe
ok, with a 01 you can install a ko4 on the revo tune and with a vagcom and lemmi/unisettings you can tune it. But then you would be trading aefficient ko3s for a slightly larger less efficient ko4. Your not really going to gain much for the money spent. w/m would give you better gains and cost 1/2 of what a ko4 cost new.
Old Jan 1, 2008 | 11:49 PM
Mya4T's Avatar
sorry if this sonds stupid but w/m?
Old Jan 1, 2008 | 11:53 PM
cincyTT's Avatar
I'm make believe
water meth injection. It cools down the intake temps and increase the octane rating (meth is 116 octane) among other things. This will let you increase boost and/or timing either manually or with a 100oct tune
lisek99
Aug 6, 2009 10:05 PM
Audi858
May 27, 2008 01:58 PM
nighta46289
Jan 26, 2008 01:34 PM
dafowler88
Dec 13, 2007 12:42 PM
Rodm21
Mar 6, 2006 11:45 AM
